Help! slave hard drive partition did not detect..
I have 80 gb hard disk used in another pc and i make it slave in my other pc. it has a partition,. but when i connect it the computer as slave, the pc did not detect the other partition.. i already format it, does not work.. Please help me how to restore my 80gb hard disk.
  • joseph790410 Sep 09, 2009
    i already change it.. it has partition, only the other partition detect by the computer.
  • 674 Answers
Did you change the jumper? make it sure that you change exactly the jumpers of each Hdd...
otherwise,not working or detecting....
Posted on Sep 09, 2009
Hello. I use Intel ZX-865 GV Motherboad with three hard disks- Maxtor 20 GB Hard Disk,Samsung 80 GB Hard Disk & Hitachi 500GB Hard Disk. Problem is,the motherboard often can not detect one hard...
As the error says, the 3rd slave hard disk (which one depends on how you have connected them - most likely the Samsung) isn't responding in a timely manner to the commands coming from the southbridge. Because of the miscommunication, the master disk on the same cable (the Hitachi) can also fail the recognition, even if there is nothing wrong with it.
This is a hardware defect: that disk is dying and there is nothing you can do to fix it. Just take out all your information out of it and remove it from the pc permanently
Jul 22, 2011 | Intel D865GBF Motherboard
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
Hi i had wd and my pc dont detect my external disk
If its xp or older OS it will not but in 4 partitions of 80 it will but most be done by outside programs most times.
Nov 29, 2009 | Western Digital Passport WDXML800UE...
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Samsung SP0802N 80GB Slave
Go into the control panel. Press administrative tools. Select computer management. Under storage select disk management. Look for the hard drive. Make sure there isn't an additional partition on the drive. If there is you can change and delete partitions on this drive as well.
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Hard disk problem
Change the other HDD to either Cable Select or SLAVE.
Then make sure you partition it correctly, Windows does a decent job at it.
Right click on My Computer, go to Manage, then under storage, click on Disk Management; you should see the HDD here.
Dec 09, 2007 | Toshiba (HDD2188) 80 GB Hard Drive
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
