Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA d52w25 52 inch blinks 3 times off...turns on...off
Push on buttton...tv squels....blinks 3 times...then turns off...does this three times then dont work at all for 5 min. then all over again?????help good fuse on main cb???
  • 3 more comments
  • james165 Sep 10, 2009
    thanks..anything helps..so i replaced the hor.output tran. and when i turned it on it did what it should do ..no noise..then about 25 to 30 sec. later it made that squel and turned off. its still the same and the new hor. output is blown again..didn't check the voltage transformer,any suggestions...
  • james165 Sep 11, 2009
    Yeah i know,when you say high voltage tran. is that also called the flyback, and can you test them somehow to see if it is bad?
    do you know how to check the high voltage tran. to see if its good,the hor.out.tran.was blown.
  • SD Tech
    SD Tech May 11, 2010
    If it blew the new transistor either the high voltage transformer is bad or something else in that circuit---hard to do much with sets like this because no schematics seem to be available and most of the boards are no longer available.
  • SD Tech
    not a solution but first--all these RCA sets have a three strikes and you are out--means they will try to turn on 3 times and if not they shut down--the high pitched sound suggests a shorted horz. l output transistor======some of these sets have a problem where the high voltage transformer goes and takes the transistor with it---if you have a meter to measure resistance I can tell you where to look. Do not take this the wrong way---these are very poorly made sets--I refuse to repair them==junk.. Aside from that--if there is anything I can do to help you let me know. SD TECH
  • RCA Master
  • 8,617 Answers
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Posted on Sep 11, 2009
Panasonic 32-inch LCD TV Blinking 3 Times. Not Turning On. Please Help.
http://www.tv-forums.com/forum/TV_Equipment_C4/LCD_TV_Forum_F41/Panasonic_lcd_Tc-32lx60l_with_blinking_stby_light._P151410/
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the APh
board, A board, or the LCD panel.
Jul 19, 2015 | Panasonic Televison & Video
WELL MY TV WHEN TURNING IT ON IT BLINKS THREE TIMES AND SHUT OFF
If RCA--it is 3 strikes and you are out---design from them set will attempt to turn on 3 times and the go into shutdown.
It means a short or problem in set--technical inspection needed.
Mar 11, 2012 | RCA HD52W59 HDTV Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Your tv problem
Yes my tv did blink 3 times but sounded like it was going to turn on. What problem is this?
Jun 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fixing a tv
57 inch rca....Sounds like you have a itc222 chasis but cant be sure... what is your model of the set. d52w20 maybe.. or something simular.. blinks green 3 times sound familar... get me that model number and we cant start the troubleshooting process
Mar 03, 2008 | Televison & Video
Tv wil not turn on
The horizontal output transistor is most likely shorted, it's a 2sc5588 Rca Part # 259899 and there are a couple of subs available for that too.
The slight squealing you hear is the feedback voltage on the hot transformer as the B+ tries to increase and the s/d circuit cuts it off. Not an expensive repair...
Good Luck!
Bill
Feb 10, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
914 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
