SOURCE: I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
SOURCE: I inherited a Ryobi 14
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
