I have philips 107 e6 computer monitor (crt ) when I connect the data cable to the case of the computer no data display and the led of the power turn on and off / on and off ...................................etc
    President:
  • 2,022 Answers
Make sure your cpu is booting by pressing the num lock key it is on and off that means your cpu is on without error if you not getting the lights on num lock key while you pressing it that means there is problem with cpu display .you can fix this eror by removing the ram form system and clean it and fixit again.
Posted on Sep 09, 2009
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
When I start my computer up my Philips Monitor
Good day sir/maam, hi, the problem may not be your monitor but your PC, they produce the same symptoms if your PC has no video to display. does your monitor led/lamp lights up as turn on your computer? If you want to test your monitor, go bring it to a friend who has a computer, test it there. if it works, your pc has a problem, so try the following first.
  1. Open you PC side cover, locate the memory module, remove the momory by releasing the side clamps. clean the contacts using an eraser (pencil) then put it back, you will clicks as you put it back on, test again. Do it several times if the first try fails.
  2. Check your Power supply, does it gives out hot air exhaust?
  3. Did you hear one beep, (good) or several beeps(bad).
  4. As you power on the pc check your keyboard light, first set of lights (Num lock+Caps Lock+ Scroll lock) then second set of light (Numlock only). At this point your pc is good.
Hope this helps, let me know your progress.
Oct 08, 2009 | Computers & Internet
Philips 107 E5 Monitor; display compressed into lower half
This is partial frame collapse and can be caused by a power supply issue supply the frame driver or the frame driver circuit has a problem with an IC or driver transistor. It should be relatively cheap to repair at a computer or TV shop but you may want to consider buying a cheap replacement monitor from eBay etc as the repair may cost you more than the replacement given everyone seems to be dumping CRT based monitors in favour of newer LCDs etc.
Aug 30, 2009 | Philips (6G3B11) for 107E51, 61, 107T51, 6...
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
I have a compaq 15" monitor which has no display.
1.poewr LED blinking or not.if in case LED blinks one time. problem in LOT .Cheak horzontal Transistor also.
1a) power out put voltages
2.drypoints in neck board.
3.cheak display cable.
Dec 19, 2008 | SAMTRON 55V 15" CRT Monitor
Phillips 201B4 turns off 2 seconds after power up
first you need to check if your coputer it is powered on. try your monitor to other computer and other monitor to your computer to see where is the problem
Dec 09, 2008 | Philips 201B4099 21 in.CRT Conventional...
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
My philips monitor is not working so how can i get technical support?
1.How is this powered? From a separate power supply or direct into the monitor. 2.Does the power light come on when switched on. Can you see any movement in shadowy form on the screen? 3. Check the data cable both ends for bent pins. If the moniot is powering up the connect it to another computer to confirm Monitor or Computer? Do all this and answer the questions clearly then come back
Jun 01, 2007 | Philips 107E66 17" CRT Monitor
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
