Question about Linksys Ultra RangePlus Dual-Band Wireless-N USB 2.0 Adapter
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the dual band router on USB port 1. My phone VOIP has been dropping off the line at least 1 per day. Tonight the VOIP will not connect. After attempting a reboot of the cable modem, the wireless router and the VOIP. The phone still doesn't work.
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Posted on Oct 06, 2009
Which are the best Wireless Routers under $200?
Some of the best wireless routers available under $200 are:-
? Linksys WRT1900ACS Dual-Band Wi-Fi Gigabit Router
? ASUS RT-AC68U Wireless AC1900 Dual-Band Gigabit Router
? TP-Link AC1900 Wireless Dual-Band Gigabit Router
? NETGEAR AC1750 Wi-Fi Cable Modem Router
? TP-Link Archer C7 AC1750 Wireless Router
You can check and compare these wireless routers at:
Best Wireless Routers 2017 Reviews and Comparison
Jan 07, 2017 | Best Computers & Internet
Tip
Globe Broadband Modem-Router
Globe Broadband provides a [SINGLE Ethernet port] modem-router / gateway with custom firmware to prevent consumers modifying the settings, for example changing it to bridge-mode if you have a Linksys Router.
Click here for more...
on Mar 06, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I bought WRT54G2 router , but could not detect the broadband connection ,,,
do you have the broadband modem plugged into the wan on the router and is the cable you are using good. and also check to see if your internet is working. you should be able to connect your computer to the modem and get internet. if your broad band requires you to log on the modem before you get out you will need to connect directly to your router and set it up per the instructions.
Dec 24, 2009 | Linksys Wireless-G WRT54G Router
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Installation
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and if your ISP is dsl configure the router settings by setting your isp username and password
Step 7: test the Internet connection.
May 07, 2008 | Linksys Wireless-G Broadband Router
Hooking linksys to gigafast
There are some question's that should probably be asked before we begin. Generally a wireless adapter or network card is present in a computer to allow it to access a wireless router which is connected to an internet service provider (generally a dsl connection through a phone line or a cable modem from your cable provider. Your request seems to be to get a computer to talk to a wireless router to talk to a wireless router to talk to your internet service provider (dsl or cable). I will assume after reading this that you probably have or will get a wireless adapter for the computer to talk to one or both of the wireless routers you appear to have. Wiring two wireless routers in the same house may be useful if the home is large or the wireless routers operate on different bands (a, b, g or frequencies) and you have different computers that require the different bands. however both wireless routers are in my experience connected to each other using a wire. Once we clarify the above we can probably address the connectivity issues for the devices you require.
Dec 02, 2007 | Linksys Wireless-G Broadband Router
Linksys Ultra RangePlus Dual-Band Wireless-N USB 2.0 Adapter Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
