Question about Watches
Metal band too small on 126-06 Massimo Watch.
I have a Massimo Wrist Watch. It looks like size 126-06 Watch, i think it takes a V377 battery, just trying to give you the best description of the watch but anyway I broke the metal band on it because it was too small. I was wondering if i could some how get some links or a larger metal band for it?
Please try to find here: watches online
Posted on Sep 09, 2009
How do you take remove the metal band off of a rolex watch
Turn it over and get a small jewelers screwdriver and insert it onto the spring bar and lever it off ..look on YouTube for a video
Aug 16, 2014 | Rolex Daytona 116520 Wrist Watch
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How do I reduce the size of a metal watch band to fit my wrist better
mcdevito75 here, You"d need a special tool called a link pin remover, BEST BET, look for a small watch repair shop in your area, hold onto the extra links once removed as you may need them again.
Jul 12, 2010 | Watches
Pins keep popping out when watch band gets snagged. What size are the pins for watch band?
mcdevito75 here, These pins may be a bit worn in the band of your watch, if so, you"d have to order a kit with various size pins for replacement. BEST BET, look for a small watch repair shop to fit new pins in the band.
Jul 12, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Need a new watch band
mcdevito75 here, Ebay is a great place for your watch band, but you should know the watch band size in MM, or you can look for a small watch repair shop in your area.
Jun 17, 2010 | Locman Titanio Tonneau LOC/484/CRBRD/BK...
Older casio triple sensor has small metal bands(clips?)around the batteries ,how do you remove the old ones?
These small clips are just hooked around small prongs. You need a VERY small screwdriver (now that i think about it, a needle may work). Just pry the looped ends up and lift gently. I have done this a couple of times, however when I replace my batteries nothing happens. Last time I had to send it back - some info stated there was another battery deeper????? That is why I am looking into this now.
RDF
Mar 02, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
Changing a Rolex metal watchband to a leather watchband
Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
Then repeat the same at the other end of the band.
Measure the distance between watch case lugs- this will be exact size for your new leather band.
Rate me, plesae.
Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
Watches Logo
188 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
