Question about Echo Garden
I HAVE A ECHO PB 500H LEAF BLOWER.I TOOK THE THROTLE HANDLE APART AND CANT GET IT BACK TOGETHER.I CANT GET THE ROUND COPPER CONNECTOR PEICE BACK IN THE HANDLE THE CORRECT WAY.
  • 666 Answers
SOURCE: would like owners guide and parts manual
Go to following site
www.echo-usa.com/documentation.asp?Model=pb210e&lang=E
Posted on Mar 24, 2009
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 666 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
  • 211 Answers
SOURCE: I can't get full throtle power out of my 44cc Echo
hi
disassembly and clean the carb,fuel filter changed
savumihai71
Posted on Nov 04, 2009
Gas/ oil ratio for pb 500h
What are you asking? I am LP tech.
Aug 25, 2016 | Echo Garden
Echo PB 500H will start and idle but dies under wide open throttle.
turn back on fuel adustment screw for high this will let more gas to carb or rebuild carb
Aug 14, 2014 | Echo Garden
How do I remove and clean fuel filter on Echo Blower model PB-500h
remove he hose attached to the filter inside the tank. pull filter out and rinse with some clean gas then blow compresses air after dried and re-install. or just remove old filter from hose in tank and replace with new filter and re-install.
Dec 04, 2012 | Echo Garden
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
Echo blower, squeeze trigger , no power
thier is a metel wire that connects the throtle control to the carburator check to see if the wire is disconnected at the carb or the ubder side of tye throtle control trigger.
Nov 18, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo pb-251 will not rev up
throtle cable has come off from the carb
Jul 27, 2010 | ECHO, Inc. PB-251C Handheld Blower
Open Questions:
Garden Logo
199 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
