Question about Whirlpool Duet GHW9150P Front Load Washer
How do I access the pump filter?
I have an FL model Whirlpool washing maching that is not draining. I read that the pump filter may need to be cleaned. I located the access door on the bottom left. Inside is a black lid that I assumed I would need to turn counter clockwise but it does not budge in either direction. Any tricks to open this?
  • 83 Answers
No specific tricks. Try gripping the knob with an adjustable wrench for more leverage.
Posted on Sep 09, 2009
Where is my pump filter whirlpool duet front load washer
When your Whirlpool washing machine won't drain, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
1 - Unplug the washing machine. Lift the front end and place two-by-four blocks under each foot to keep the front elevated. 2 - Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. Remove the panel. The drain pump assembly is directly in front of you, in the middle of the machine. 3 - Unscrew the knob on the drain pump by turning it counterclockwise. Hold a bucket in front of the pump while you remove the knob to catch the water. There may be as much as 2 or 3 gallons. 4 - Turn the knob over. The filter is on the back. Check the filter and remove any debris or lint. Replace the drain filter onto the pump. Screw on the access cover. Take the machine off the blocks and plug it in.
Dec 21, 2016 | Whirlpool Washing Machines
E1 F9 code front load washer whirlpool duet
When your Whirlpool washing machine won't drain, or is displaying the E1 F9 error, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
Whirlpool washing machine AWM 5100 has stopped going thru the full cycle.
My machine did a similar thing and in my case, it was debris in the filter. It took several clear-outs before the object appeared.
Mar 21, 2012 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
Hi.
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an FL code on the screen
the fl code on this machine usually means that there is a problem with the drain pump or something to do with the draining process. if you turn your machine up and look on the bottom most calypso units have a access panel that can be removed from bottom requires to remove a few screws ..there is a drain pump on the middle right side of unit ...there is either an obstruction in the pump ,one of the hoses to the pump or the pump has failed itself.... hope this helps you out and good luck....
Jan 06, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
The digital box shows the letter FL. We cannot get maching to operate. We cannot get the FL off the box.
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*!@$
Jun 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code reads FL...
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer will not drain
Well i think you should be looking in the filter? Or in the pump. These are the only thiongs that will stop it from draining or spinning! The machine will not spin if it has water in it. It will go into spin inhibit to protect the machine. Check for lost items and then look at pump/filter if nothing then replace the pump then you will be ok.
Jan 02, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
