Question about Dryers
Why do the orange buttons bottom front of gas fired 80k twin come on occasionly and glow
4 Suggested Answers
SOURCE:
dniro592006
  • 121 Answers
SOURCE: kenmore 70 gas dryer no heat
your thermostat controls the heating
Posted on Jun 12, 2009
garing
  • 998 Answers
SOURCE: Maytag dryer cycles through 2-3 times of gas being
need to replace coils on gas valve
Posted on Aug 15, 2009
protek480
  • 1730 Answers
SOURCE: Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 31, 2009
LG Trom gas dryer dlg5988B got under water 10 inch. The motor is running, just the gas heater does not burn. Computer is working right. Any idea?
Take top off, start drying cycle and see if you can see an orange glow on bottom right front of unit-the Glow plug igniter. If it glows, then you have a different issue. If no orange glow, replace igniter.
Nov 26, 2017 | LG Dryers
Fisher & Paykel dryer orange glow under dryer while operational.
gas driers use a flame to heat the drum for the drying so there will be a flame some where in the unit
when in doubt get in a technician to check and /or repair
Jul 13, 2017 | Fisher Dryers
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
I do see an orange glow at the bottom. No heat
its a bad ignitor
the glow should be almost white hot
this heat is what opens the gas valve
dont go looking for a fuse
Oct 03, 2009 | GE JGBP24 Gas Kitchen Range
Have a LG gas dryer dlg7188wm....doesn't heat
Take top off, then start unit. You can see orange glow in about 10 seconds on front bottom right by looking down from the top if the glow igniter is working.
Jul 27, 2017 | LG Dryers
Kenmore Gas Dryer Model 75731 Dryer Won't Heat
The orange glow is the ignitor. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Kenmore 63942 Dryer
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
No heat
Should be a cover about the size of a quarter on the front lleft bottom...pop off with a small screwdriver and start dryer....look inside and see if the glow bar lights up...if glow bright orange, probably good, may need gas solenoids or ignitor
Jun 10, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer
There should be a gas igniter, inside of the burner chamber, that will glow bright red before the gas will be allowed to flow. If the dryer model that you have has a flap on the front you will be able to observe this otherwise you will have to remove the front of your machine to check it. If you post back with your machine model number I will be able to assist you further.
Mar 12, 2007 | Maytag MDG2706A Gas Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
