Question about Dell Computers & Internet
My server blinking yellow on led harddisk indicator led
    President:
  • Dell Master
  • 2,017 Answers
Which model server you have this may be hardisk fault just remove the hard dive and fix it agian.
Posted on Sep 09, 2009
Powers on then off with 4 red binks then 2 amber?
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the (ones digit) of the Error Code.
Example: If the Error Code is "37", the LED will continuously blink Red three times, followed by blinking Yellow
seven times.
25846923-00ymvd0zfh3oypxbgkhcneuw-4-0.jpg See the following for a list of Error Codes.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds
then restore power.
http://electro-medical.blogspot.com/
Sep 02, 2015 | Mitsubishi WD-73638 3D-Ready DLP HDTV
Tip
Colour full BlackBerry ..If you are a Blackberry user.You must read this
In BlackBerry LED indicator blinks in different colors to deliver different notifications to the user:
Blinking RED: The LED indicator blinks red whenever you have incoming or waiting communication messages on your phone - new email, new call or missed
call,
Blinking GREEN: this is Coverage Indicator light. This lets you know you are connected to a network.
Blinking BLUE:If your phone is connected to a Bluetooth device, such as a Bluetooth headset it blinks blue.
Blinking YELLOW: A blinking yellow light means it is time to charge your BlackBerry
on Dec 15, 2009 | Cell Phones
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Yellow light shows in hdd of server
This means that HDD is faulty . You can confirm it by re fixing the hard drive .
Shutdown computer > Remove HDD > wait 1 min and Insert it > Start computer .
If you get any of the below status
Steady Amber (Orange Led) = Drive is Faulty
Amber Blinking = Hdd rebuilding
If orange led blinks , it means hdd is in rebuilding state. Wait for sometime and check if it come online . On the other hand (Steady Amber) its time to replace HDD
Good Luck
Apr 26, 2012 | IBM x3400 Server
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
IBM xseries eserver x236 Bios problem: a yellow light( !) like this is on and IBM server can not start
Try this:
Light path diagnostics
Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
Good Luck
C2Solutions
Dec 31, 2010 | IBM eServer xSeries 236
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Blinking red and yellow light
Generally if both the (red) alarm LED and the (yellow) data LED are both blinking, it is an indication that the tone cartridge needs to be replaced. You should be close to out of cartridge.
Jan 12, 2009 | Brother HL 1440 Laser Printer
Yellow machine server.
Is it just the fault led, let the machine run for a while and see if it starts rebuilding the drives, if it is NEW and you have just installed the drives and never installed the software then you will get a fault I have the q400t which is the platnum version tho they still call it the p400t if you have just received the server then what u must do is power off the server plug in the netcable into one of the 8 lan ports run the install till it tell's you to turn it on then hit next then follow the instructions to setup the server
Dec 30, 2008 | Anthology Solutions Yellow Machine P400T...
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Computers & Internet Logo
149 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
