Question about ViewSonic VA721 17" LCD Monitor
Viewsonic memory recall problem
Im gettin a popup memory recall ok? from last one week....and the buttons are not workin and contrast and bright are changing automatically.........plz gimme a solution for it sir.......
RCtech
  • 55 Answers
SOURCE: Issue with my 17" Viewsonic VA1716w LCD monitor
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Posted on Dec 10, 2008
Astrophel
  • 116 Answers
SOURCE: Brightness/contrast menu popup
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Posted on Feb 02, 2009
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
pravinbhavsa
  • 348 Answers
SOURCE: Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Posted on Feb 28, 2010
SOURCE: Viewsonic VG2021m contrast/brightness menu won't go away
I had same problem. The solution I got was to unplug power cord, and hold down each switch on monitor for 30 secs and switch on. IT WORKED! Hope it helps you too.,
Fred
Posted on Jul 12, 2011
Memory recall option is Continuosly blinking on the screen and also brightness option also too..what to do with this problem
This is the exact same problem which I am facing at this moment. I opened the Case of the monitor. I saw that there are 2 small buttons with a extended rod attached which goes into the buttons on the Monitors body. I saw the Contrast button and the brightness and the Menu button are stuck. I also saw that the monitor pads and the monitor sensor board has complete rust. I think I have to change the button pads and the Monitor Board. The same thing I am seeing in your case. I think this is a cause of Excessive moisture content in the air which is causing rust and jamming of Buttons.
I think now you can get what to do.
Thank you Sir, Have a nice day.
Sep 23, 2009 | ViewSonic E70f 17" CRT Monitor
Brightness pop-up window on screen
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
'memory recall ok' displayed always on the screen. Does not go even if selected yes or no. Why?
I got the problem solved. The other day i called up the viewsonic tech support, service engineer visited and changed the switches inside. the problem got solved. So call up the tech support of view sonic at (india)
We need the following details to create an RMA Request for your Product.
Once an RMA request is created our service Engineer will contact you within 2 Business Days to attend the call.
1.Customer Name
2.Phone no with STD code
3.Complete Address
4.Model and Serial No of Product
5.Description of problem
We can be reached on this email address or through phone on our Toll free No1800-11-9999 or Toll No:-011-26990006
Have a Great Day Ahead.
Thanks & Regards
ViewSonic India Technical Support
bye
Nov 04, 2007 | ViewSonic G90fb 19" CRT Monitor
MEMORY RECALL OK? problem
or you have a "crazy" micro or have a stucked push-button (or two) , first I try is change them or at least disconnect it to see what happen.
Jul 11, 2007 | ViewSonic E70b 17" CRT Monitor
Memory recall
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Oct 31, 2006 | ViewSonic E70 17" CRT Monitor
Memory recall
Oct 30, 2006 | ViewSonic E70b 17" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
ViewSonic VA721 17" LCD Monitor Logo
95 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
