Question about Amana Refrigerators
Water is leaking from the rear of the refrigerator
  • 555 Answers
If the appliance have water dispenser and/or ice maker, the water line may be leaking, if so, needs to be re-installed again. Check the user manual for recommendations about the water line installations.
If there is no water line, looks like the appliance is installed in a location with high levels of humidity as the compressor is not able to evaporate all the water collected by the freezer. Check that the fridge door closes correctly and the seal door is good.
Posted on Sep 09, 2009
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
Apr 09, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Leaking Kenmore Refidgator
What is your model number? Sears Kenmore numbers look like this 321.2468102 I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil. Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? Yes the water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up stopping the waterflow downward to the condensate pan below refrigerator. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain line. How a refrigerator leaks is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example of a ET18PKXGTO Whirlpool refrigerator leaking water into a cup below the freezer compartment. Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 19, 2013 | Refrigerators
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Uhhhhhh
There could several reasons for the water under refrigerator. Leaking water connection to water control valves. leaking defrost condensate pan or blocked condensate drain beginning inside freezer rear wall cause by ice or other gunk caught in the defrost drain line. Because leaks always happen differently on every model I will give you a page to look over and watch a small clip about fixing a refrigerator leak. One moment as I retrieve the information and links. Sea Breeze
Dec 22, 2009 | Maytag MBF1956HEQ / MBF1956HEW /...
Water is leeking below the refrigerator. I cannot see where the leeking is coming from. Any ideas where to look?
Dec 22, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
May 12, 2009 | Whirlpool 18.8 cu. ft. Top Freezer...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
110 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
