Question about Refrigerators
Ice forming in the back panel of the subbzero refrigerator
I have ice forming on the inside back panel of my 501 subzero refrigerator. I have had 3 service people check it and have had 3 different diagnosis- compressor problem, freon leak and fan/motor not working. Has anyone had and fixed this problem
    President:
  • 2,976 Answers
The door seals are leaking. They are allowing moisture in and it is freezing.
Posted on Sep 09, 2009
Refrigerator whirlpool wbm 501
Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
Feb 07, 2014 | Refrigerators
Subzero 695 Ice/Water dispenser problem.
maybe ice formed around chute from leaky air seal??? warm area with hair dryer blowing hot air up into chute for 10 minutes. check for water and wipe all off. unplug refg and plug in after 3 minutes to reset electronics
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero 590
Ignore the fan operation... That is perfect.
You are likely experiencing a DEFROST failure
(most commonly a defrost timer failure)...
part number 3081180 item 69 on your exploded
top view (top right side as viewed from the front).
There are typically only three (3) elements to a DEFROST
circuit:
- Defrost Timer (as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per YOUR DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
guaranteedparts.com http://www.guaranteedparts.com/picture_library/Subzero/Subzero-500%20Series/590.pdf
Sears
http://www.searspartsdirect.com/refrigerator-repair/symptom/REF0003.html
Carnac the Magnificent
Apr 06, 2017 | Sub-Zero 690 Side by Side Refrigerator
Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Nov 12, 2009 | Sub-Zero Bottom Freezer Refrigerator
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Sep 06, 2009 | Sub-Zero 561 / F
Ice is forming on the backwall inside the refigerator portion of my side by side sub zero
It is probably low in refrigerant that means there's a leak in the seal system , you should contact subzero beacause they give a 10 years warranty on this.
Jul 27, 2009 | Refrigerators
Ice froming at the bottom of the refrigirator
Check that the drain is clear. If it is blocked water will back up and spill on the floor and can potentially freeze. Otherwise you may need service to install a drain heater.
Jun 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice forming in refrigerator
Sounds like the defrost system is not functioning properly. There are a lot of possibilities -- probably ought to call service unless you have significant experience with appliance repair.
May 08, 2009 | Refrigerators
Subzero 685 water dispenser won't work
check the water resevour it is probebly frozen up arpound the outlet of it. its inside of the refrigferator, towards the back of the refrigerator down towards the bottom. take a hair drier and thaw it out.
Jan 16, 2009 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
