Question about HP DeskJet 690c InkJet Printer
HPdeskjet690c yellow flashing light
I have done all the 8 steps of checking for all the reasons fo rthe flashing light. I have cleaned the cart. heads and where they match.
I have unplugged and replugged. I have done the same for the parallel connection. A few times after doing this the light will stop flashing, but as soon as I send a print job to it, it is back doing it and nothing happens I don't know what else to do.
This started when the ink was running low, it sat a few weeks till I could get the ink replaced and now nothing.
What do you think?
1986 ez electric 4 seater golf cart serial # 438359
re wire the golf cart. poor ground and possible battery replacement needed
Sep 15, 2016 | Golf
"The yellow 'Alarm' light will not go off after changing cartridges.
Try removing and reinserting the cart. Or try a new cart. It sounds like it's not recognizing that a new cart has been inserted. It could be a faulty/sticky switch where the cart is detected.
Jun 21, 2012 | Canon Office Equipment & Supplies
Hallo I have a problem with my EPSON sx415. I bought new analog ink cartridges (not genuine). I puted it in my printer and tryied to print. But paper was white. So I decided to clean printers head with...
you will have to spend more money my friend! the epson ink is called durabrite, the cheaper cart you got is water based, the head should have been flushed before hand to remove the durabrite ink, what has happened is the 2 types of ink have mixed in the head and set. the only way to fix this is to remove the head from printer and have it ultrasonic cleaned, i had the same problem and tryed cleaning products with no affect! the only wat is to get it ultrasonic cleaned, or if you have the epson carts, put them back in and try and get it exchanged if still under a year old. as a new head is about the same price of the printer, however argos has the printer on offer at this min for only £39.99 which is cheaper than ink. oh yea, the reason that the printer is now not seeing the carts is that doing back to back cleans emptys a new set of carts after only 5 or 6 head cleans so your new ink is now useless, sorry for the bad news.
Dec 24, 2010 | Epson Office Equipment & Supplies
When i print it prints clear and there is no ink on the page, but it is making the noise as though it is printing.
have you done head cleaning ? after few clean, is there any ink on your print out? if still no print out.. make sure the ink cart tab is removed when you installed a new ink.. most of the time, when user removed the yellow tab, they fail to see the residual tape on the ink cart which is blocking the air path which is needed for the ink to flow into your print head..
some cases, check your printer purge unit.. see if the tube is not disconnected as if the tube came off..there won't be any pressure to clean your print head .. it's bit technical to fix it back..
May 23, 2010 | Epson Stylus CX8300 Printer
Yellow not printing on test print -
You either have a leaking cart or the print head has become cross contaminated. Remove all the carts and check the feed hole under each of them. Make sure they are the color of the ink in the cart. Remove the print head and, using a damp cotton bud (water ONLY!) give the print head a clean. DO NOT use the same cotton bud for all sponges.
If that doesn't solve it then take the print head to a re-inking firm and have it cleaned professionally. Won't cost much and will hopefully solve the problem.
Sep 14, 2009 | Canon Pixma iP4500 InkJet Printer
Yellow cartridge stopped workin halfway through a document although nearly full
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Print head
Check that all, printhead and ink are seated and contacts are correct.
Power down the printer and allow for a complete power on and self test.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Epson C66 problem
Without the benefit of a response from any of rickyostrom, liusgarciaca, or hotdog233311, I think we can say the problem lies with the fact that your magenta cartridge isn't printing. You can confirm this by carrying out a nozzle check print.
If any of you would like further assistance in restoring your magenta to working condition, please do a new post to this effect.
Oct 29, 2008 | Epson Stylus C66 InkJet Photo Printer
Printer freezes up
You should also check that is not a driver problem, by reinstalling the drivers from lexmark.
Mar 13, 2008 | Epson Stylus Photo 1280 InkJet Printer
HP DeskJet 690c InkJet Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
