Simpson 705 washing machine shakes on spin dry
Washing machine vibrates excessively when on spin
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Excessive bowl swing on spin cycle - machine cuts-out. SIMPSON 22s650. tried adjust load balance but still wobbles to cut-out. Sometimes OK with an under loaded light load.
Sounds like it needs new suspension rods. One on each corner. The spring on the rod gets weak causing excessive bouncing & swinging.
Jul 17, 2017 | Simpson Washing Machines
Simpson washing machine problem have taken out stainless steel wash bowl and the plastic top/seal around it has water in it is that normal for that to happen
Yes. Some have water & some have sand in that ring. It is a balance ring to stop vibration when bowl spins. Do not empty it.
Jun 27, 2016 | Simpson Washing Machines
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
Simpson eziset750 washing machine that washes but don't spin
Lid switch / drip dry botton on / wash/spin solenoid fried /
Aug 12, 2013 | Washing Machines
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
