Question about Epson DFX-9000 Matrix Printer
I hv an epson 9000 dfx printer (high speed printer). i am hving the following problems. 1. it shakes a lot while printing. 2. while in the middle of a print job, the printer suddenly stops. the status changes from 'printing' to 'error-printing'. on restarting the printer , the print starts again from 1, instead of resuming from the point last printed.... say 41st or 42nd page. cd u pls help? a lot of time, stationery and effort is wasted.
ohms
  • 1879 Answers
SOURCE: epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Posted on Jan 22, 2008
SOURCE: DFX 9000 error oC
epson dfx 9000 error code od
Posted on May 12, 2008
Inky
  • 691 Answers
SOURCE: error 07 ,turn off Printer on dfx 9000
The motor (+42 V) or head drive (+37 V) voltage fell below the
allowable level.
This error indicates a power output problem, or a voltage detection circuit failure.
Check and replace the following in the order below, checking
functionality at each step:
Power Unit
ROM Board
Posted on Jul 23, 2008
ohms
  • 1879 Answers
SOURCE: PROBLEMA IMPORESORA EPSON DFX-9000 ERROR 3
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
Posted on Sep 11, 2008
ohms
  • 1879 Answers
SOURCE: Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Posted on Nov 20, 2008
Need a print head for Epson DFX 9000
Spare parts you have to order via Epson, but I'm not sure they still have print heads for matrix printers.
I found a site in China, but perhaps you even can find more on Google? dfx 9000 print head
Jul 27, 2014 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Print heads for dfx 9000
if you replace the printhead and dont change the alpha an beta value, your printheat was damage shortly
Feb 05, 2009 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 printing from DOS nework
can i ask a free download driver for my printer bjc-80v?
Feb 01, 2009 | Epson DFX-9000 Dot Matrix Printer
DFX 9000 Printing problem
when i switched on epson dfx9000 printer its showing Error 01,Pls give the solution.
Dec 17, 2008 | Epson DFX-9000 Matrix Printer
Re dfx -9000
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable.
2. Load plain, single part tractor paper into the printer.
3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
>Try printing from other applications.
>Check cables as they can cause communication errors.
>Re-install the driver.
>Go to support.epson.com for more information & documentation.
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
Request
This error OE is linked with the Print Head Driver.
2 solution:
1- Check the print head cables (continuity, shortcircuit, connection etc..
2- Print head Driver on the Main Board is out of order > Change the Main Board.
Mar 17, 2008 | Epson DFX-9000 Matrix Printer
PDF printing with DFX 9000
Actually, the issue that your having is a software issue. You need to check the settings of the reader. Try to contact Adobe and ask help for its settings. They're phone number is 1-800-945-9120.
Feb 06, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
