DOES NOT GET COLD . WHAT IS THE MATTER
  • lbf May 11, 2010
    This may sound rude but with the information you're giving, all I can tell you is: It's Broke. Give more information please, ie: does it run, make strange noise etc.
  • 128 Answers
Check the setting of thermostat must be on cool then check the compressor is operating if all are operating mens you to check the freon chargeis low.
if the compressor is off check power on compressor terminal and also check its body if is hot replace the capacitor.
Posted on Sep 09, 2009
Stutters on start
Sounds as though your battery is suffering for low cold cranking amps,may need to replace it .I know you said temperature does not matter ,cold crank amps is just another way of saying amperage capacity .You may have enough to just start it but it is on it's way out.Have it checked at an automotive place like Auto Zone or Advanced or Sears if you have one close by.
Mar 09, 2013 | Cars & Trucks
Servis model M3905W does it matter if the hot and cold water are connected up the right way round and if so what isthe right way round?! Thanks
Makes a big difference. Cold water valve is is normally marked blue or simply cold water. connected to cold water tap. Hot water marked with red colour or simply hot and connected to hot water tap.(Red hose - Hot water. Blue hose- cold water.).
May 27, 2010 | Washing Machines
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
It doesn't matter if the car is hot or cold. it
Clean battery cable connections , all three of them and replace bolts.
Sep 25, 2009 | 1992 Buick LeSabre
1986 VW Golf - blows cold air out vents
add coolant....if that doesnt work...check the thermostat...then if its not that its the water pump
Jan 14, 2009 | 1986 Volkswagen Golf
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
