Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a johnson outboard motor that drips oil from the prop.why is this ?,maybe a seal is blown?
  • 677 Answers
Yes the prop shaft seal needs to be replaced.Do this sooner than later as water will get into the lower g/box.Sometimes they wear out or fishing line is a bad culprit.Its not a big job but it really needs to be done.The oil will also need replacing.Hope this helps
Posted on Sep 09, 2009
    Champion:
  • 202 Answers
Wait a minute It might just be exhaust residue see if water in gear case if it is real black it is probably exhaust soot from the motor
Posted on Nov 11, 2011
  • Ron Hutton
    Ron Hutton May 30, 2012
    I have the same problem and it is the exhaust soot. It never used to happen and now it seems to all the time. I do a lot of trolling and that adds to the exhaust residue.
  • 23 Answers
There is a good detailed instruction on removing the propeller shaft seal and bearings in the SELOC manual. Worth the price. Tells you how to deal with the fact the bearing carrier won't budge. Worked for my 135 hp Johnson.
Posted on Oct 30, 2009
1966 Johnson outboard 9.5hp. Lower unit oil leaking past prop. What parts do I need and how to install it.
drive shaft oil seal and possible shaft
take it to an outboard service shop as it may require special tools for the job
Aug 01, 2017 | Johnson Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
What year model is a mercury outboard 4 horse with serial number 3303712?
call a mercury dealeris all I can tell you .we handled johnson /evinrude.
Jun 17, 2014 | Light Outboard Motor Boat Bass Fishing...
What are the signs for a blown head gasket
if water in rad has oil in it or smells , building up pressure in rad , water in oil !
Feb 23, 2013 | Sierra International 18-2959 Marine Head...
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Dark oil coming from inside prop
might just be carbon from the ehaust . do you disconnect fuel line and leave motor in gear when hauling . wind sucks fuel thru the engine
Apr 26, 2010 | Light Outboard Motor Boat Bass Fishing...
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 | Boating
Gear Lube leaking from Prop
Keep an eye on it and put a bucket with paper inside under the motor. You want to know whether the oil is burnt oil from the exhaust or gear lube. You should be able to tell from the color of the oil. Its kind of like soot in a chimney, the exhaust goes through the prop with the oil you added to the gas.
Jun 27, 2009 | Light Outboard Motor Boat Bass Fishing...
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Dec 23, 2008 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
710 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
