Requirements (hardware + software) in PC to connect phone via bluetootth
  • 742 Answers
You just need a "Bluetooth Adapter" buy a bluetooth adapter and insert it in your PC's USB port. Windows will automatically detect and install it and then you can use it immeadiately. Just make you phone's bluetooth settings to be VISIBLE so that the devices will see each other in the bluetooth network
Posted on Sep 09, 2009
I received a PC camera from a friend and since the
Driver is a software which runs the hardware, here you will need a proper driver to run or use your hardware (pc camera).
Lets begin, connect your pc camera to your pc, go in control panel> Devices and printers> and click add a device, it will scan your hardware connected and will download required drivers via windows update. Thank You.
Oct 09, 2013 | Computers & Internet
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
I REQUIRE LATEST SOFTWARE UPGRADE NOKIA 5800
The latest software version of Nokia 5800 is version 60.0.003.You can do it via OTA (over the air) thru GPRS (mobile service providder's internet gateway) or via wi-fi connection or even via PC suite.
OTA via GPRS:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your mobile service provider's connection.5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA Wifi:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your wi-fi home network connection5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA PC SUITE:
Go to this address and follow instructions (make sure that you have available USB cable for your phone for you will need to connect to your pc to do this):
www.ovi.com/softwareupdate
thanks for choosing fixya.com
Dec 17, 2011 | Nokia 5800 XpressMusic Smartphone
How to connect this phone to pc and connect to internet
It depends on the phone: Motorola phones generally can use a software tool (Motorola Phone Tools) or can directly connect via USB or Bluetooth. The iPhone requires jailbreaking, and can connect via an application over wifi, Bluetooth, or the usb-based cable. I am not as familiar with HTC or Blackberry phones, however I have heard the android phones may require an application or natively support, blackberry uses bluetooth or usb... Then there are the Verizon phones which can act as a mobile WiFi hotspot. It all depends.
Oct 01, 2010 | Computers & Internet
How to fix message error 900.00 service RIP software on Lexmark c 530 dn
Does the error pop up when the printer is booting up, receiving information via network, connected via usb, or connected via parallel cable? It could be two problem. If it would post during printing, then it could be cause by a software or network problem. Test the printer in a standalone mode without any usb or network connection, if the error would post upon power up and without any network connection or usb connection then its a hardware problem. If it's a hardware problem, it would require a service call.
May 10, 2010 | Lexmark C530dn Laser Printer
Bluetooth
Sorry but you can not installed blue tooth on the dis device.
Blue tooth is not only a software. I t also requires hardware.
Sorry.
Aug 20, 2009 | Sony Ericsson W200i Cellular Phone
Nokia 6300 headset detection problem. what to do? is it the hardware or software problem?
Download the Nokia Software Updater from the Nokia website and connect your phone to the PC via USB and update your firmware. I had the same exact problem and I was sitting on v6.02 and I just upgraded to v7.21. My headset is now working properly. Good luck with it!
Jul 08, 2009 | Nokia 6300 Cellular Phone
How to install themes of motorola l7 from computer
Use Motorola phone tools software to access your phone via USB cable then upload to phones theme folder from there
Feb 10, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
