Question about Samsung S85 Digital Camera
Wen i turn it on it makes a beepn noise then cuts off with no picture
    President:
  • 2,761 Answers
There may be something more serious wrong with the camera, but the problem you describe is frequently due to weak/wrong batteries or corrosion on the battery contacts inside the camera. Make sure that your batteries are the correct type for the camera and that they are fully charged. If all seems OK with the batteries, remove them and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Posted on Sep 09, 2009
Car won't start . Clicking noise wen key is turned
It's your starter. Find location of your starter. By the flywheel. Then. Bang on it . Your car will start. You still need to replace the starter.
Dec 08, 2011 | 2004 Honda Accord
My Hotpoint Aquarius TVM570 started making a funny noise then cut out... I changed the fuse to see if it was that but no luck. You can turn the timer but as soon as you press 'start' it just trips...
if you check this link it shows the basics for getting in the dryer ,, after that , you may have to remove the vent tube inside ,, you will see a fan attached to the back of the motor, your missing Rib could be rubbing against that or possibly even the drum as it turns,, be sure and unplug the machine anytime you remove the back
Jun 12, 2011 | Hotpoint Dryers
I put in fresh batteries and camera still wont turn on.
wen i turn it on it makes a beepn noise then cuts off with no picture
Aug 18, 2009 | Samsung S85 Digital Camera
Nissan primera 2000,just this week having probs wit low revs wen idle or wen slowing down,cut out a couple of times &started after 5-6 mins also bad rattle or clunking noise wen breaking seems to b...
you may need to replace the sensor or relay for the transmission. about the brakes, try checking the disc pads, it may be too thin, have it replaced
Jul 03, 2009 | 2003 Subaru Forester
Drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
May 11, 2009 | Frigidaire Electric Dryer
Is a noise wen i turn the weel all the way
Check the level of power steering fluid in the reservoir, there should be a dipstick for that. Make sure its within the specified amount. If its not try adding some. Also there could be air in the power steering system, and if you had the fluid changed somewhere i would reccomend bringing it back to them and having them bleed the system.
Dec 15, 2008 | 2005 Cadillac CTS
Samsung S85 Digital Camera Logo
108 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
