Question about Garmin nuvi 750 GPS Receiver
Won't turn on
Can't add a lot because i left it in my friends car, and when i got it back it won't do anything. i know it was working no more than 48 hours prior. it does not have a smell, like the board on the inside could have been overcharged or something. although i did notice that the sticker with the serial numbers and info were missing, which left the screws completely visible. so they might have opened it up for some reason, but i honestly can't say whether they did or not. i just know the sticker is missing so now even if i wanted to turn it into the manufacturer, i can't cause it doesn't have the information on it and they probably messed up my warranty by opening it up. anyways any ideas to help me get it working again are greatly appreciated. i am lost without it, i LOVED IT!!!!!!
    President:
  • 1,111 Answers
Plug it in to the wall charger or car chargerwon't turn on - 2.gif for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Posted on Sep 09, 2009
I have the Nuvi 755t
the problem is a bug in the software updates. to get mine to power on again,***be very careful*** all i did was pop the back plate off. there is 2 screws. some people say #5 #6 or #7, to be honest, find one that fits yours. once that is done. the back plating is just snapped it. now, the tricky part is to uncover it without harming the wires that are connected(speaker and battery). once the back plate is off and you see the inside, take twezzers and pull the battery wire so it becomes disconnected. count to 30. then place and push gently the wire back in. snap the cover back on fully. carefully screw the 2 screws in. PRESTO!
anyhow, this worked for me. however if there is any sign of trying to open the unit, the unit becomes void of warranty. if you can do it precisely, without making and marks or nicks while trying to get inside the unit, then your ahead of the game. if something else should happen again.
Posted on Sep 14, 2009
I am trying to add KaseyCarter Evans to my facebook friends and to chat and send an app for a game it wont work
type lkasey carter into the search box
find her as there are a lot of results
click on the one you know is her
click on add friend
Feb 14, 2015 | Facebook Apps
Tv won't turn on
Check for input power in outlet. Try connecting the TV to a different power outlet you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | RCA L22HD31 22 in. LCD HDTV
I recently won an E10 in an auction. I did not receive any paper work or anything with it, so I don't know a whole lot about this little camera. But what I do know is that when I turn it on, it go
There are other complaints all over the internet about this cameras' battery life. Are you using NiMH batteries or alkaline? If you used 8 you must be using alkaline. If they are heavy duty regular batteries you are using the wrong kind of battery. NiMh hold more power and last longer with a flatter power curve up till they are about done. Recahrging means not buying lots of batteries too. They should last for a long, long time; like a week or two at least. The manual and quick guide can be downloaded in PDF from http://www.ricoh-imaging.co.uk/en/Photo-Downloads.html
Jul 22, 2012 | Pentax Optio E10 Digital Camera
My bpanasonic 48 won't turn on the light blinks
I may if you know what the model number is which is not indicated here.
Jun 14, 2012 | Televison & Video
My 1999 Silverado 5.3L automatic won't shift from 2nd to 3rd until 2500 rpm when it's cold. When warm works fine but 1st to 2nd shift won't happen until 2500 rpm, speratically. Transmissio
I had a friend that had this problem.I work at a G.M.dealership and I ask a friend that does trans work there.He said this is normal in cold weather.This is done in order for the trans to reach operating temperature sooner.This could be why you are unable to fix this problem because it is normal.I looked in service info to see if I could find a bulletin or something to back this up but I did not find anything.I know this guy very well and I know he knows his work and is good at it.Hope this helps.Good luck.
Feb 25, 2012 | 1999 Chevrolet Silverado 1500
Need to replace left turn signal flasher
This is weird! It seems to me that the left turn signal is getting 12v from somewhere at all times.I don't think the flasher is the problem(most GM systems use a single flasher for left and right)You probably have a crossed wire somewhere(or an add on accessory was connected to the left signal wire,allowing 12 volts to bleed through to the circuit)
Dec 31, 2011 | Pontiac Bonneville Cars & Trucks
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My TV won't turn on - it was working fine when I turned it off and now it won't turn on...
have you checked the fuse at the back??...this just might be your problem. It is located on the power supply side of the motherboard.
Good luck and thanks for using Fixya.
G..
Jun 29, 2011 | Mitsubishi WS-48613 48" Rear Projection...
Add songs
IF U WANT TO ADD THE SONGS TURN ON UR BLUE TOOTH .......... ASK UR FRIENDS TO SEND THE SONGS VIA BLUE TOOTH ..... AUTHENTICATION WILL BE ON UR SCREEN .. ACCEPT IT .. SONG WILL BE DOWNLOADED ...SAVE IN THE MEMORY ALWAYS .... BECAUSE MOTOROCKR WE DONT HAVE A LOT OF SPACE IN PHONE ...
I. AND IF U WANT TO SEND THE SONGS AND VIDEOS TO TRANSFER ... ASK UR FRIEND TO TURN ON THE BLUE TOOTH .......... SELECT A SONG AND CLICK ON THE LEFT SIDE BOTTOM ICON.. WHERE U LL FIND THE SEND OPTION >> CLICK ON IT AND SEND IT VIA BLUE TOOTH
PURCHASED MOTOROCKR RECENTLY
. AND NOW IAM CRYING LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
Nov 21, 2008 | Motorola Mobility ROKR E6 Smartphone
I can not add friends in Face Book
Try to delete your cookies/ cache from the browser you are using, if this doesn't change anything let facebook tech support know. hope this helps :)
Nov 15, 2008 | Facebook Social Network
Garmin nuvi 750 GPS Receiver Logo
221 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
