Recently visiting ftp://ftp.Steinberg.net/ Archives...And trying to look for Up dated Drivers,and downloading same.Was met with the prompt (does not support 'Cpuint32.dll').Could you assist as to how i can resolve this problem. Terry Jenkin arbiter@crawler.com
  • 742 Answers
The ftp site has not supported the type of download you triggered. it also matter what bwoser you used in downloading the files. but i tried it with google chrome (new browser from google) and it really messed up when clicking a file for download. but here's a trick i did that made me download a file successfully:
Right-click in the file that you want to download. Click "Save link As"
Im using chrome. the command maybe different in firefox or IE
Posted on Sep 09, 2009
Steinberg CI1 USB doesn't light up when plugged in
I restart with the CI1 plugged in) but I can't 'get it' in Garageband. I've tried the Garageband preferences, and system Audio section, but there's no device to select there - only internal mic.
Be sure to get the latest update from Steinberg.net
And in Garageband you'll find your unit in preferences - input
Dec 16, 2013 | Cubase Steinberg CI-1 USB Studio Audio...
FTP Connection using Windows 7 64 bit
Individual applications that transfer files using FTP may have their own methods for monitoring transfer speed. But for a single method that works across all applications, consider an external bandwidth monitor. Windows no longer tracks bandwidth usage, but several free third-party tools display your upload and download speed. Close other Internet programs besides your FTP transfer tool, and check the bandwidth monitor to determine your transfer rate.
Net Speed Monitor
If your computer uses the 32-bit version of Windows 7, download Net Speed Monitor 2.5.4.0 for Windows. If your computer instead uses the 64-bit Windows 7 version, download Net Speed Monitor 2.5.4.0 for Windows (msi, x64). (See Link Below.) http://www.floriangilles.com/software/netspeedmonitor/download/ Run the installation program. The license agreement will open. Accept the agreement. Click "Next." Further options will open. Click "Next." Click "Install." A dialog box will ask whether you want your task bar to display the "NetSpeedMonitor toolbar." Click "Yes." Another dialog box will open. Click "Save." Run your FTP transfer. Check the transfer rate from the task bar. Bandwidth Meter b> Download the Bandwidth Meter installation program. (See Link Below.) http://www.bandwidth-meter.net/freedown.htm Run the program. Click "Next" through the options. Choose "Install" when the final step prompts you to. Run your FTP transfer. Check the transfer rate from the task bar. Hope this helps.
b>
Dec 17, 2012 | Esker TUN Plus 11.5 Upgrade Version for PC
A fake trojan antivirus wiped out my ability to access the internet using both i.e. and firefox. The fake program has been removed and now I want to reestablish the connection to the internet using...
if there is any other software (that your system came with) that was wiped use your recovery disk...now go to start/all programs/accessories/system tools/system restore...you will pick a date (approx 1-2 month ago) restore to earlier date...pick a date click ok...the system will shut / reboot up again and prompt you do wish to continue you must click ok (yes) to the restore date..try your ie or ff
Jul 10, 2010 | Dell Computers & Internet
Dell dimension 4600 ethernet port/driver issue
The link for the drivers is ftp://ftp.us.dell.com/network/R67150.EXE
If runningit directly does not install the driver go to Device manager and right click on the ethernet adapter and update the drivers. Use the manual method and browse to c:\dell\drivers\R67150 for the driver location. also the latest .netframweork is downloadable from here.
Aug 07, 2009 | Dell Dimension 4600 PC Desktop
I have been trying to download the drivers for Lexmark printer Z53 for a week. I've tried several times on two different computers and keep getting error "message 1603 error installing Microsofft.net...
Windows Update error code "0x643" and Windows Installer error code "1603" are generic error codes. Typically, these error codes mean that the update was not installed. These errors codes are usually caused by a corruption in the .NET Framework installation or by an inconsistency on the MSI database state.
Method 1: Manually remove and reinstall .NET Framework loadTOCNode(2, 'resolution'); To manually remove and reinstall the .NET Framework, follow these steps:
  1. Remove the .NET Framework.
    1. Click Start, and then click Control Panel.
    2. Double-click Add or Remove Programs.
    3. Note each version of the .NET Framework that is already installed on the computer. Then, uninstall all the versions of the .NET Framework.
    4. When you are prompted, restart the computer.
  2. Use the Windows Installer CleanUp Utility to clean up the MSI database state for all the versions of the .NET Framework.
    1. Download the Windows Installer CleanUp Utility. The following file is available for download from the Microsoft Download Center:
      Download the Windows Installer CleanUp Utility package now. (http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe)
      For more information about how to download Microsoft support files, click the following article number to view the article in the Microsoft Knowledge Base: 119591 (http://support.microsoft.com/kb/119591/ ) How to obtain Microsoft support files from online services Microsoft scanned this file for viruses. Microsoft used the most current virus-detection software that was available on the date that the file was posted. The file is stored on security-enhanced servers that help prevent any unauthorized changes to the file.
    2. Install the Windows Installer CleanUp Utility as an administrator or as a user account that is a member of the local Administrators group.
    3. Click Start, point to All Programs, and then click Windows Install Cleanup.
    4. In the Windows Installer CleanUp Utility, remove all Windows Installer applications for the .NET Framework.
  3. Restart the computer.
  4. Download and then reinstall all the versions of the .NET Framework that were previously installed on the computer.
    To download the .NET Framework 1.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en) To download the .NET Framework 1.0 Service Pack 3, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en) To download the .NET Framework 1.1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en) To download the .NET Framework 1.1 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en) To download the .NET Framework 2.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en) To download the .NET Framework 2.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en) To download the .NET Framework 3.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en) To download the .NET Framework 3.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en) To download the .NET Framework 3.5, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en)
  5. When you are prompted, restart the computer.
Note When you have reinstalled all the versions of the .NET Framework, you can use Windows Update to check for updates to the .NET Framework.
Dec 02, 2008 | Office Equipment & Supplies
XP on HP Pavilion dv2000
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
http://downloadmirror.intel.com/16023/a08/infinst_autol.exe
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Conexant High Definition(HD) audio :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
http://downloadmirror.intel.com/16944/a08/win2k_xp14363.exe
Download the Ricoh 5-in-one Card Reader Driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37712.exe
Download Intel PRO/Wireless Drivers from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34489.exe
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33574.exe
Realtek Ethernet Drivers :
http://drivers.softpedia.com/progDownload/Realtek-RTLRTLRTLRTL-Driver--WHQL-Download-33009.html
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
ftp://ftp.hp.com/pub/softlib/software10/COL24713/gs-63707-1/Marvell_Yukon_LAN_Driver_6.36.0.0.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the HP Quick Launch Buttons drives from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Download the HP Pavilion Webcam Driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Alps Touchpad driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33751.exe
Finger Print Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32869.exe
Hope these helps...
Oct 03, 2008 | HP Pavilion dv2000t Notebook
I want to add my cx3200 epson printer to my pc have lost the cd rom disc
Download these two drivers in order and install, follow prompts to know when to connect printer.
Printer Driver
ftp://ftp.epson.com/drivers/epson10453.exe
Twain Driver
ftp://ftp.epson.com/drivers/epson10573.exe
Hope this helps
Thanks!
Feb 27, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
