Question about Eljer Toilet Onepiece Canterbury 081162047
Eljer Canterbury one piece remove flush valve
I, too, have an Eljer Canterbury one piece. It looks like the shank washer has disolved over the years. (Darn bleach tablets!) I picked up a replacement at Home Depot, but I can't figure out how to remove the flush valve itself. (Have already tried a new flapper--including a second one that resealed the valve with putty and a smaller opening.) Presumably I need to remove the valve from the toilet, insert the washer, and then put the value in again. I'm sure this thing needs to screw in the toilet some how. A plumber told me to take the toilet off and that there'd be a screw underneath to unloosen. The toilets off and there's nothing there. For those not familiar with the model, it's a one piece. Thanks.
Any ideas? Thanks.
  • scott_howley Oct 07, 2009
    I've looked down the flush valve and at the end (non-flapper side) I can see four square plastic pieces jutting into the valve itself. Presumably you could insert a tool which would make contact with those and allow you to loosen (or tighten) the valve to the toilet. If I've understood the suggestion correctly I would need to find the tool, insert it into the flush value and turn counter-clockwise. This would allow me to remove the valve, replace the rubber washer, and then I would re-insert the flush value and re-tighten the washer? Do I have that right and if so where would I find the tool? I've been to HD a couple of times and haven't found anybody there who has even the slightest clue--even though I bought it from them. Thanks.
  • Anonymous Mar 12, 2014
    Replacement parts
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Posted on Jan 07, 2010
  • 2 more comments
  • bbshamsian Jan 07, 2010
    Well the picture I uploaded is not very readable so here are the instructions:
    The flush valve of an Eljer one-piece toilet looks like the picture at right (Photo 1). Notice the four (4) tabs in the center of the valve in Photo 1.
    To remove the flush valve, it must be unscrewed from the tank bottom. The following instructions describe a handy tool used to easily remove the valve.
    Yon will need:
    - A 1-1/2" (381nm) diameter PVC pipe about 14" (356mm) long
    - A straight, sturdy device such as a metal rod or large/long screwdriver to use as a handle
    - A Hacksaw
    - A Drill
    On one end of the PVC pipe, mark 12 o'clock, 3 o'clock, 6 o'clock, and 9 o'clock positions with a pencil or marker. At the four marked positions, use a hacksaw to cut 114" (6mm) wide and 3i8" (9mm) deep notches. Once the cuts are made, the end of the pipe will look like Photo 2.
    At the opposite end of the pipe, about 314" (19m1) away from the end, drill a 112" (13mm) hole through the pipe, to accept a suitable handle such as a piece of metal rod or long screw driver.
    To remove the Flush Valve using the Tool:
    First, remove the flapper from the flush valve. After removing the flapper, use the tool to remove the flush valve by inserting the notched end of the pipe over the tabs in the flush valve. Using the tool handle, turn the tool 1-1/2 to 2 counter-clockwise rotations. Lift out the entire flush valve reservoir.
    You have now completed the removal of the flush valve.
    This is a note for search engines to find this solution/page:
    Above instructions are for creating a Flush Valve Removal Tool for Eljer One-Piece Toilets.
  • hutchandmal Aug 25, 2011
    perfect - I suspected it would be this easy - but it's nice to know for sure
    I'll make the tool tomorrow
    Thanks
  • John V May 25, 2013
    any way to get the instructions emailed or a link... this is awesome but I cannot read the small image...thanks!
  • 49 Answers
All you should need to do is shut off the supply valve. then remove the suply on the toilet side. now where the supply connectts to the tank there should be a plastic nut which will release the assembly your after
Posted on Sep 20, 2009
On most Eljer one piece toilets, the flush valve, (not the fill valve) has a cone shaped nut on the bottom that flares out the rubber washer sealing the tank. It is tightened by inserting a tool inside the hole under the flapper, and turning clockwise. Removal is just the opposite.
Posted on Oct 07, 2009
Occasionally after flushing ,water continues to trickle slightly in toilet bowl. Have changed flapper twice. Wondering if the seat that the flapper sits on is worn or something. It looks ok. Have a one...
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Feb 27, 2011 | Eljer Toilet Onepiece Canterbury ...
Eljer flush valve is leaking how can fix?
There is a large slotted screw in the center of the flush valve. Use the biggest straight bladed screwdriver you have with nice sharp edges to loosen if not remove screw. Once you get it loose at least you will be able to tilt it out at an angle. that's how I got mine out. now all I have to do is find a new one!!!
Nov 28, 2010 | Eljer Toilet Onepiece Canterbury ...
Hello.I live in an older mobile home. We just moved it on the property this past september. Our problem is our toilets rarely fill so that we can flush them. We usually have to fill a bucket with water and...
you have debris in the flush valves. if they are older toilets, I would replace the flush valves. you can get the eljer fill valves from your local plumbing wholesaler.
Aug 07, 2010 | Eljer Toilet Onepiece Canterbury ...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Want to know how to remove the flush alve on a one piece toilet.
Open the rear lid of water closet. on the very inside rear of the flush valve there is a very then nut it unscrews in the clockwise rather then counterclockwise. I think that was the problem
Jul 01, 2009 | Eljer Toilet Onepiece Canterbury ...
Flush valve
it is all one piece,replace it with the same model. a plumbing supply house is the only place you will find what you need.
The flush valve to Canterbury is broken and i need change
In the one piece units, there is usually screws that fasten the flush valve onto another piece directly under it. If you would call them, they can guide you to the information you are requesting.
972-560-2000
800-423-5537
Monday through Friday
8:00 A.M. to 5:00 P.M. EST
Mar 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
5,388 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
