Question about Danby Freezers
I made a hole inside my frezeer is there an way to
I made a small hole inside my frezeer is there an way to fix it
  • hsalas7 Sep 09, 2009
    no is not, I was trying to get something out and hit the walls and made a small hole
  • Controlfrk
    Controlfrk May 11, 2010
    If you mean in the refrigerant piping and you got sprayed with refrigerant, NO! This repair is likely beyond your abilities and possible not a good value depending on the age and price of the freezer.
  • 34 Answers
Did your refrigerant leak out? If so, I would go buy a new one. I have not been able to find a product that will repair these holes satisfactorily.
Posted on Sep 09, 2009
How to fix small hole on flooring inside freezer
Aluminium plate glue it in place
Apr 06, 2015 | Freezers
My frezeer can not star
You need a new regulator. get the manufacturer and make and numumbers and look it up and save hundreds putting it in yourself.
Bob12367b@aol.com
Dec 19, 2011 | Turboair 49 cu. ft. Upright Freezer...
My frost free freezer is building frost on the top part of the freezer between the door and the small divider, the seals appears ok with no gaps and it never shuts off 2006 model
there are two vent holes in the bottom of the door that need to be seal closed there has been air leaking in from these holes also the rear air diffuser should be solid and the vent holes in it coverd as well.then you nee to take one or two small washers and remove the front panel inside the freezer and put the washer between the panel so there is a small gap between the top of the freezer and the divider
Sep 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
My AEG Arctis freezer is not freezing at the correct temperature and seems to stick on -11 even if I put the fast freeze on.I have turned it off for 24 hours and on again but it still does not hold the...
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
Oct 05, 2009 | AEG 10.35 cu. ft. / 293 liter Upright...
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 | GE Freezers
Motor runs, doesn't freeze
ok if compressor is running the you have a leak or restriction if frezeer is under five years old call the manufacture to get it fix but you have to be sure is running if is not running the it just might be the overload repl it and it will start again
Nov 02, 2008 | Freezers
Kenmoew 4.8 cu ft 13.6 lt chest freezer
need more info model what type of frezeer
Nov 01, 2008 | Kenmore Freezers
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Jan 01, 2008 | Freezers
Freezers Logo
102 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
