Question about Alesis RA-150 Amplifier
Power up problem with alesis rs300 (ra300)
I have an alesis RS300 power amp (same as RA300 but silver). I accidentally unpluged and pluged it in while it was powered on. It still has power but both yellow lights on the ends of the meter (the ones that come on and turn off after the capacitors have charged) are on and do not turn off. When I opened it up I found rg1 and rg2 resistors had burned. I replaced those and tried to power it up and still have the same issue. Are there any suggestions as to what I should try next?
any help would be great, thanks
    Problem Solver:
  • 6 Answers
Replace the crappy chinese made TA7317 "protector" SIP IC after verifying that no DC voltage is at the amp output prior to the protection relay. These chips are nothing but problems.
Posted on May 06, 2010
    President:
  • 1,348 Answers
You have more than likely damaged some transistors.
the resistors have burned because of excessive current.
there are 2 typesof transistors,bipolar and mosfet
a bipolar transistor has 3 pins.1) base 2)emitter 3)collector.
an NPN is tested with the + meter lead on the base , and a PNP transistor with the - lead on the base.
TESTING
base to collector should read .5 to .6 v drop in one direction and open in the other with a digital meter on the diode check function.
base to emitter about the same,but slightly higher than the collector.
if base to collector is .5v then base to emitter is .52 or so.it is always higher than the base collector number.
between emitter and collector will read open in both directions.
if there is a short on any lead combination,the transistor is blown.
npn transistors operate on the positive rail power supply,and pnp on the negative rail.
typically a 150 watt amp will run + - 65vdc.
the transistors running on the plus side are npn and on the negative pnp.
most pnp output transistors are green.,but some are black,
so we must go by the numbers on the transistors, eg.A1076 is a pnp,B755 is a pnp and all transistors that have a C or D eg. D424 are NPN transistors. all A and B numbers are PNP and all C and D numbers are NPN.
MOSFET transistors have 3 pins 1)gate 2)drain 3)source
the source goes to power like the collector does. the drain is like the emitter,and the gate switches it on like the base does.
testing a mosfet is a different procedure.
a mosfet with k then a number e.g. k135 is a positive device like npn.
a mosfet with j and a number e.g. J50 is a negative device like pnp.
a mosfet reads open source to drain both directions.
for a positive (k number device) the plus meter lead goes on the source.,the black meter lead on the drain. on the diode test function.
jump a wire from the source to the gate for 1/2 second and remove the jumper while leaving the other two meter leads connected to the source and drain.The mosfet should switch on and the meter should show a short.that means the mosfet switched on.About 5 seconds later,the resistance from drain to source should go open.
for a p channel mosfet,it checks the same,except that the black meter lead goes on the source and gate .
a mosfet will stay switched on longer than the voltage applied to the gate,if it is driving a high impedance device such as a meter.
a bipolar transistor will not stay on when voltage is removed from the base lead.
i hope this has been of some help.
Posted on Sep 09, 2009
My phone was immerse in water it has power but no picture
well yoy have software problem try to warm up phone but don turn it on it may destroy your entire hardware.reload a new software it may cost upto rs300
Jun 09, 2011 | Cell Phones
Hello. RA300 used only in a studio environment, never pushed hard. During a mastering project we lost one side of the amp. Thanks!
The first things to check are the devices on the heatsink. They do all the work so tend to go when pushed! Remember stereo amps are just two amps put together, so at least you have a good channel (which is the same as the bad one) to do tests with say an ohmeter.
Apr 27, 2011 | Alesis RA-150 Amplifier
How do you remove the knobs on an RS300
Either by sheer force or if you can see a hole in them, by an Allan Key.
Feb 06, 2011 | Alesis RA-150 Amplifier
I have an elesis RA 500 it blows the slow blow fuse when i plug it in .any ideas what is wrong?
hi there,
it sounds like the internal transformer has gone.
It's not user replaceable and will require you to take to an electronics store to be repaired.
SAME THING RECENTLY HAPPEN WITH ONE OF MY BITS OF KIT ...... for heavens sake don't just keep changing the fuse time and time again.
Jan 07, 2011 | Alesis RA300 Amplifier
Alesis RA 500 makes a "clicking" sound and no more sound. later it will "click" on again
Clicking sound is a protection relay. This means one of the power amp sections have failed. Or that your speakers connections are faulty
Sep 24, 2010 | Alesis RA300 Amplifier
Alesis RS300 Reference Amplifier Channel malfunction...
You say "it seems like". Do you mean to say it is intermitent, or did it start cutting out and then finally fail? If that is the case I would look first to replacing the relay in contention in this thread.
http://www.fixya.com/support/t224708-amp_cuts_out_after_while
It's a cheap fix and will eliminate one potential cause. The Radio Shack part is widely available.
http://www.radioshack.com/product/index.jsp?productId=2062483
My RS-300 had started dropping the left channel, but occasionally both. It is possible that the relay has failed on one side and thus you have a dead channel...I did the fix and am now quite happy with the amp
Steve
Dec 26, 2009 | Alesis RA-150 Amplifier
Took my RA300 and Tannoy Reveal X speakers to a cellar party for halloween. No drinks were spilled or anything but it had an ipod plugged into it most of the night and the volume on the amp turned to max,...
Normally when people bring their HI-FI to a party they tend to fix up the leads to the speakers in a flimsy manner ( as it is only temp) . With the crowd mulling around these leads(wires) could very well come loose or even short out. This leads to your Final Drive ( Output Amp) to short out. It is not an expensive repair. Check your final amp & replace any shorted/blown items. To get full satisfaction the job best be handled by the local agents of the amp.
Nov 19, 2009 | Alesis RA-150 Amplifier
Amp not powering up
Chek transfomer with a multi meter set on continuity,check primary input across wires AMPLIFIER MUST NOT BE PLUGGED INTO WALL SOCKET...check outputs low readings in ohms are good no readings mean open transformer(buggered
I suspect outpuit stage short as this probably buggered relay in first place
Jan 07, 2009 | Alesis RA-150 Amplifier
Alesis RA-150 Amplifier Logo
823 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
