Question about Viking VWH3048 Kitchen Hood
Viking hood Lights out
We have a viking range hood, similar to the VWH3048, the difference is ours has the 1200 blower. The other day, both of our lights went out. We thought it was strange that they went out at the same time, but we went ahead and changed the lights. To our dismay, the new lights didn't come on. Is this something that we can fix ourselves? Any ideas on what happened, my husband thinks that it is either a short or the sockets burned out. Any advice would be appreciated.
  • Anonymous Mar 21, 2008
    same problem - lights went out!
  • Puffjohnny Oct 27, 2008
    I have th e vwh4848 model with the same problem. Also, I need a new variable speed switch for the blower and new knobs. Any auggestions?
    Problem Solver:
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Posted on Mar 17, 2009
    New Friend:
These series of posts were really helpful. I have a Viking 60 inch hood and the lights stopped working. Fan works fine but not the lights. Doing little research I came across these posts so I thought I would give the fix a try. I found Viking Part PE050141 online, and then traced it to an actual store in Chicago. I called them; they had it in stock and picked it up. I prepped the work area by covering everything in case a screw or anything else might fall. After removing the hoods filters, I removed the heat lamp shield closest to the light switch. See picture, it is help in place with 2 screws. To my surprise, this whole was big enough and close enough to the switch connections to replace them. I was fortunate as I did not have the unscrew and lower the panel to can access to the switch. It was still tight getting to the black wire connected and yes it was greasy and I did scrape my knuckles a bit. But after the black wire was connected, the red one was easy. The new switch went in easily into the panel and, bingo, all the lights worked again. The appliance company wanted $189 to just show up and parts would be additional, so for the cost of the part and a little time, I was able to get this fixed.
Viking hood Lights out - viking-hood-lights-out-re0uluplpqljbvjiggqjtxom-5-0.jpg
Posted on Aug 01, 2015
    New Friend:
As posted above, it was the dimmer switch. I removed the filters, then the 2 screws on either side; careful! The entire front underside will come down and it's a lot heavier than you think! Before dropping it from the rear, ensure you remove the two outlet type blower plugs or you risk more damage. Ocne these are removed the unit will drop about 6". Use a flashlight from the opposite side to see what is going on as you will only have access from the sides; it greasy and you will get scratched as stainless is unforgiving. Probably best to have a friend help too. All in all, an easy fix, take you time and get ready to be slightly dirty.
Posted on Jan 15, 2013
It may be as simple as a wire coming lose from the on-off switch. The on-off switch pulls straight out (with a bit of back and forth coaxing). Check to see if both wires are attached. Vibration from the hood can loosen them over time.
Posted on Mar 02, 2009
    Problem Solver:
  • 6 Answers
Dimmer/thermostat is bad. part # PE050033. you can change part yourself with a little mechanical aptitude.
Posted on Feb 25, 2009
4 Suggested Answers
mcalnan
SOURCE: Viking 10 inch hood lights out
I'm just an average do-it-yourselfer....this was more intimidating than it really is. Go to www.allvikingparts.com as long as you know what model number you have the guys there will make sure you get the right part.
1) Throw the breaker to the circuit the lights are on2) Remove the grease traps and trim from the front section of the hood3) Remove the 3 sheet metal screws slowly from the hood....the hood will fold forwards about 6-8 inches...don't go too far4) Disconnect the existing dimmer...I found it was easier to work with by disconnecting the red wire first, then carefully push the on/off switch from behind to disconnect the black wire. Remove the dial and carefully unscrew the nut holding it in place....remove defective unit.5) Snake the black wire through where the on/off switch goes and connect it (they don't give you alot of play in the wiring so be careful. Attach red wire. Test it to make sure it works. Place the toggle back through the whole and carefully screw it back in. Replace the dial.6) Fold back into place and screw 3 sheet metal screws back in....7)Put grease traps and trim back together....
8)Brag to your buddies what a great handyman you are....and your wife too!
Posted on Oct 28, 2011
ginko
  • 19396 Answers
SOURCE: Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Posted on Apr 05, 2008
i have the same problem what is it
Posted on Oct 21, 2008
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Vents in the Viking hood fall out on their own
Remove the filters.
The slot that the filters sit in at the rear edge, can be removed, it is basically hooked into place.
When you remove it you will see that the sides are different, reinstall it with the smaller edge hooked thus leaving the larger edge to hold the filters in place.
I hope this is clear.
Dec 12, 2008 | Viking VWH3048 Kitchen Hood
It is more than likely the dimmer switch has gone bad and needs to be replaced
Nov 06, 2008 | Viking DTWL4848 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
VWH 3648 Hood
most of them you have to take the filter off. under the filter, there are some screws. take them out and then it should drop the motor and you will see the electrical.
good luck
Jun 21, 2008 | Viking VWH3048 Kitchen Hood
do the heat lamps work?? or is it the 4 bright lights you are having the problem with??
Viking hood damper
Remove the blower and reach up into the duct through the back flow damper and put weather stripping on the 2 edges that are chattering, it will greatly reduce the noise
Dec 20, 2007 | Viking VWH3048 Kitchen Hood
Viking VWH3048 Kitchen Hood Logo
2,565 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
