Question about Microsoft Windows Vista Ultimate Edition
I KEEP GETTING ERROR 815 WHEN I TRY TO CONNECT MY BT PHONE HUB .
    Problem Solver:
  • 6 Answers
Hello friend
aap ka phone 815 ko sport nahi kar raha,
because aap ke phone ke software main error hain
updat karo software 100 to 120 ka charg hoga mobile or 815 ok hain
Posted on Sep 13, 2009
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
How do I connect my new BT hub 4 wirelessly to my HP F4580 printer
Keep Pressing the BT hub button until the light continuously burn. Search your BT name in the printer bluetooth device. connect it using the PIN 0000.
Dec 28, 2014 | HP Open Box Deskjet F4580 All In One...
Android tablet not connecting to my bt hub
Delete the connection from your Android device, select your home-hub and enter the password again. If that doesn't work, try restarting both your tablet and your home hub and try again. If you still have no success, changing the type of security the home hub uses can help.
Mar 19, 2014 | Computers & Internet
Phone is displaying DHCP:discovery boot ver 02.01.00.04. Mitel phone was working perfectly until router changed to BT Hub. What can I do to resolve it?
You can download the TNA analyzer to test ports. Or your router is not giving dhcp to the phone. You can try to statically assign an IP address to. The phone.
Feb 18, 2013 | Mitel 5224 IP Phone
Iphone 3G-S will not connnect to BT Home Hub 2.0
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub.
Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting.
Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether.
Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect.
Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
Aug 06, 2009 | Apple iPhone 3GS Black (16 GB)
Bt home hub (shuny black one) wont connect wirelessly
Try to disable the netgear interface and let windows manage the wifi card. This could also be happening if the signal is not strong enough where the machines are.
Is your wifi hub also a netgear? If not it may not be compatible with the cards if that is the case you will need to replace them with diffrent make of the cards preferably the same brand as hub.
Jul 27, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Error code 815
The error code 815 means that the broadband network connection could not be established on your computer because the remote server is not responding
I suggest contacting your Internet Service Provider (ISP) to check the issue first
If that doesnt work take a look here
http://forums.techguy.org/windows-vista-7/616358-vista-mail-problem-due-wan.html
Jun 07, 2009 | HP Pavilion dv6000z Notebook
Wifi connection to BT Home Hub problems
Make sure you do not have any third party software running in your taskbar that deals with wifi connection if your trying to use the windows connection. this is what i do. its better, and more simple. Home Hub does not work well with non BT software. If your not sure, turn any wifi connection software off. i.e if any came with your wifi device. and then click on the start button. and click connect to on the right lower side of the start menu. You can use almost any wifi device with these devices. your best bet would be to let windows try to connect to your home hub. Also are you typing in your WEP key. correctly. How far away from the hub is the wifi device. Is windows wireless zero configuration off in system services. unliekly. but worth a look. I have had a home hub for three years and i have to admit they are a nuisence. The BT Voyager wifi works ver well. just in case there is some kind of incompatibility with your device, i highly doubt it though. Good Luck.
Apr 27, 2009 | Archos 705 WiFi Digital Media Player
WHEN I TRY TO INSTALL BELKIN G ROUTER TO MY TOSHIBA LAPTOP I KEEP GETTING ERROR 815 CAN YOU HELP PLEASE.
Error 815 means that your ISP server is not responding. The probable causes are that you have not set up your connection properly - correct username and password, check with ISP support for connectivity problems
May 05, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
212 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
