Is there a standard diagnostic program to determine the condition of a WE5000aaks (WD caviear SE16) 500 gig HD? I just hate the thought of throwing this thing in a grinder and losing all that data.
    Scholar:
  • 108 Answers
Why is my Mazda not cranking up?
There is no magic "fix" button for this kind of issue. You will need to perform standard diagnostics on the vehicle to determine the fault.
Begin by reading out stored codes from the ECU to see which sensors were detecting an out-of-parameter condition, then begin your diagnosis from that point.
Things to check:
  • Timing belt;
  • Throttle Position Sensor;
  • Fuel pressure at rail (after changing fuel filter, of course);
  • Condition of spark plug wires;
  • Condition of spark plugs;
  • Operation and condition of coil pack(s);
  • Operation of fuel injectors;
  • Fuel condition (replace ALL FUEL if you suspect contamination).
May 21, 2015 | 2002 Mazda 626
Doesn't recognize replacement hard drive
What is the type of IC regulator voltage on power supply board Onkyo DV-SP502?
Jan 17, 2014 | Philips DVDR3575H/37
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Awful picture quality
if you do not have a HD source the the best you will get is 480i. as for the screen size, there is a button on the rempte marked "format" press that to change the screen
Dec 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
2002 Saturn Vue won't start
Non-start situations basically boil down to two things: No Fuel, or no spark.
I you are looking to throw a part at it, start with the crank sensor. They are cheap and not too hard to replace.
A full diagnostic approach would be to determine if it was a fuel or a spark problem. Check fuel pressures with a fuel pressure test guage: Low fuel pressure indicates a bad fuel pump or a bad fuel presssure regulator. Lastly on the fuel side, check t see if the injectors are getting a signal to fire, usually done with something called a noid light, I believe.
Spark diagnosis begins with first determining the condition, then finding the cause. Bad coil, loose wires, even the crank sensor are all suspect. A good repair manual with a flow chart is probably the best procedure to follow.
In my case, my manual only had a passing reference to the crank sensor and no diagnostic procedure to test it or even lead me to it. I found the solution through extensive web searches. Once I replaced it, all was well.
Dec 19, 2008 | 2002 Saturn VUE
Hard drive circuitry damage??
simply find a harddrive with the exact same model number and date, then swap the boards.
Nov 29, 2008 | Western Digital Caviar SE 120 GB Hard...
Can't load a 13 gig avi file onto wd drive with 90 gigs free
Typically this is because there aren't large enough fragments to load. Run defrag several times and try again. You might also run the cleanup program and remove any temporary files, temporary internet files and anything in your waste basket before you run defrag.
Please let me know how this turns out.
Nov 23, 2008 | Western Digital Passport WDXML800UE...
I have an hp a1487c with windows xp media center edition, the orginal hd crashed. bought a new WD 320 gig hd; used recovery disks to reformat the hd. the systems still crashes and has a helluva time...
It sounds like maybe a memory issue. I would suggest running a test on the ram with DocMemory found at http://simmtester.com/page/products/doc/SendDocMemory.asp?ver=3.11_beta
You may need to register at this site in order to download the program. The registration is free. I have used this program many times and it seems to be a pretty trustworthy program.
You can review the Users Guide at http://www.simmtester.com/page/products/doc/docguide.pdf
Thanks
Jul 22, 2008 | Computers & Internet
WD 120 Gig HD
There is usually only one light on the drive, which indicates that data is being read or written when the light is light.
Jun 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Please solve my other problem...
Seagate/Maxtor has hard drive tools that can recertify your hard drive. Maxblast with powermax or segate tools. Recertification tests the hard drive without corrupting contents.
I would download these and test the hard drives with the manufacturers software instead of software made for generic devices.
I ran a generic diagnostic on a WD 40 gig hd, 15min into it it failed diagnostics, got an RMA from WD sent it back and I tracked results.
They had it 2 min before sending it in for repair. I downloaded their Software and tested another wd drive, 45 secs it took to detect problems, generic software took 22min.
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
