Question about HP OfficeJet J4580 All-In-One Laser Printer
Problem with color cartridge- says refer to device documentation it was fine two minutes ago, what happened and how do I fix it?!
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
CARTRIDGE ERROR.REFER TO DEVICE DOCUMENTATION TO TROUBLESHOOT
you must replace your cartridges
propably the color one with a new one or a refilled one
Oct 17, 2010 | HP Officejet 5610 All-In-One InkJet...
Olor refer to documentation to troubleshoot
Color cartridge is failed.Replace it.It's part number is CC656AN.
Nov 17, 2009 | HP OfficeJet J4580 All-In-One Laser...
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer 4580 tri color troubleshoot
i think i run out of ink[or color.whatever the stuff in there is called]
so i will buy a new one and try to see if it fix the problem
Jul 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print Cartridges Refer to documentation (No function works)
I was getting this same VERY unhelpful error and the only thing that solved it for me was to buy another genuine HP black cartridge (350XL). As soon as I put it in, it cleared the error and sprang to life. As a matter of interest, before this happened, the HP Toolbox utility was also saying that the old cartridge was nearly empty. So why on earth doesn't the printer tell you the same thing??? Come on HP - get your firmware sorted. Disappointed.
May 20, 2009 | HP Office Equipment & Supplies
HP OfficeJet J4580 All-In-One Laser Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
