Question about Sharp Microwave Ovens
A missing piece of plastic at the top hinge...
And I an concerned about the potential for radiation leakage.
  • mmtex2004 Sep 09, 2009
    does that mean that the microwave 'seal' is ressentially the interior box 'front face' to interior door raised 'seam'? ... if that makes sense?
  • 4,340 Answers
Plastic does not prevent microwaves from escaping, I tested TONS of microwaves and stopped doing it, NEVER had one leak that had a door that closed reasonably...
You have no worries.
Posted on Sep 09, 2009
Emerson microwave 1000 watt - how to tighten door on hinges
The tool is a special so nobody can tamper with the door, you need a repairman that is equipped with this item or see if you can get one from manufacture. The microwave leakage radiation is of concern especially in near range of the unit and should be corrected quickly.
Mar 27, 2012 | Emerson Microwave Ovens
I have a Cookworks Microwave Oven Model EM717CKL. I have noticed that while it is in use, quite a strong draught is coming from the hinge side of the door. I have searched to find out if this is normal...
It depends on the amount of leak as a higher amount is not acceptable as there can be radiation leak. Please check the hinges and the door seals as there must be minimum gap to the chamber and door.
A small amount of the food flavors can be smelled while the microwave heats as this is normal. The door protect from any microwave leaking to the front and should not be a concern unless you are able to measure any stray radiation.
Mar 16, 2011 | Microwave Ovens
Electrolux oven door strained and wont close properly
Don't try to run a microwave oven with a bad door. At a minimum, you probably need to replace the door hinge plates. Unplug the oven and remove the top/bottom cover. Study the hinges and door to see how they come apart.
When you have the door back on and adjusted so it closes flat against the frame all around, take it to an appliance dealer who sells microwave ovens (you can leave the screws out of the cover and take them along in a plastic bag or other container). Have the service tech check for microwave leakage. If it is clean, you can fasten the cover and put the oven back in service. If you have leakage around the door, you may have to readjust the hinges, or the door itself is warped and must be replaced.
Mar 12, 2011 | Microwave Ovens
A plastic container with hidden piece of metal caught fire in my Sharp r1490 and burned with a big flame. Several small holes were burned in the ceiling panel. Are we in danger of radiation exposure/ is...
The microwave oven is not safe to use, the fire has compromised the interior of the oven, if you run the microwave it will start to arc and eventually short out the magnetron, because the white enamel paint has been burned away. If you have holes in the ceiling there is danger of radiation leakage, for safety reasons the oven should be replaced.
Feb 23, 2011 | Sharp R-1490 Microwave Oven
I have had my Panasonic Microwave (Model NN-CT857) just over twelve months and but have just noticed that, when the door is fully closed, there is a very small space between the door and microwave 'body',...
There must be a gap between the door frame and the oven cavity for ventilation and mechanical reasons.
The gap will need to be more than 3/8" to allow any appreciable amount of leakage through.
I am sure it is less than that.
If you are concerned, a leakage test would be the answer, from a registered and approved microwave repair centre that is Panasonic recognised.
The door can be made to fit closer by adjusting the door catch inside the body of the microwave. Just slacken the fixing screws and hold the door closed, tighten the catch holder and there you have it. A snug fit.
Hope this helps.
Nov 04, 2010 | Panasonic Microwave Ovens
How do I test a microwave for 'leakage'?... Does calling to a cell phone placed inside a closed microwave indicate 'leakage' if the cell phone rings/receives the call? Thank you
The "cell phone" test is a fraud. Cell phones operate on a frequency range much lower than microwaves (800 MHz for phones and 2.5 GHz for the ovens), and the metal screen in the microwave door won't affect them. The phone will ring loud and clear and it doesn't mean the oven is leaking microwaves.
You can buy a "microwave leakage test card" at some stores that supposedly change color when you hold in front of the door if the oven is leaking microwaves. This is also a fake. It actually responds to heat, on the thory that if heat is escaping around the door then microwaves are too. That's wrong.
The only sure way to test for microwave leakage is with a standardized leakage test meter. This is a fairly expensive electronic device. You really don't need to worry about microwave leakage unless the door of the oven is visibly out of alignment so that it isn't closing and sealing properly. If the door hasn't been getting slammed shut and the oven hasn't been dropped, everything should be fine. Take the oven to a service shop for a leakage test if you are concerned.
One final note: Microwave energy drops off rapidly with distance. Just don't stand right in front of the oven while it's running.
Hope this helps ease your mind. Thanks for using Fixya!
Feb 02, 2010 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
How to replace the door?
You can usually find helpful exploded view diagrams and order any needed parts by entering your full model number here.
If the door won't lift off when you open it all the way, then you'll have to pull the oven from the wall to take off the cover and get to the hinges.
Kitchenaid / Whirlpool customer installation manuals and owner's manuals can be downloaded here
Hopefully you can do it without having to actually remove the hinges, since that would require adjustments and leakage tests.
Oct 16, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Door constrained by adjacent cabinent
You need the "Some Other Solution". Do Not mess with the MW Door Hinges! They have been set by the factory to safety requirement to prevent MW Radiation Leakage. Altering Door Hinge could place you and your Family in harm.
Jan 30, 2008 | Bosch HMV9305 Microwave Oven
Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
