Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi,my dvd lead pin heads are stuck in the holes in the back of the tv - any way to remove them safely?
    President:
  • 1,348 Answers
They can be pulled out with tweezers or fine pliers.there is no risk of a shock since this is a signal circuit.
if you can not get them out from the back,you will have to remove the back of the tv and push the pins out from the inside.
as long as you stay away from the high voltage section and just deal with the panel that houses those jacks,you will be ok.
Posted on Sep 09, 2009
PSE ADVISE HOW WE GET DVDS OUT,THEY GET STUCK IN THE TV UNIT ? IS THERE A SAFE WAY TO GET IT OUT ??? THANKS FOR ANY HELP U CAN OFFER, WE LUV OUR GRUNDIG THAT OUR DAD LEFT TO US. ITS A MISURO HD UNIT.
Check near the DVD opening for a small pin sized hole if your lucky it will have one of it does then grab a small paper clip unbend it so it's strait insert in pin hole and put some pressure behind it hope this helps
Nov 22, 2016 | Grundig Televison & Video
Hi, i cant remove my broken dvd/bluray drive from my Fujitsu Sirmens xi 3650, i have contacked fujitsu (5 weeks ago, no luck) and downloadet all the manuels from fujitsus website but they says nothing...
Just try this;
- Unplug the computer (power Off) - Take a pin or any thing sharp enough like a pin (should be dry) - There is a hole down the disk tray in the cd drive to just insert a pin (see the image below)robertaji_5.jpg
MUST BE VERY CARFULL WITH NEXT STEP.
- now carefully insert the pin into the hole until it stuck in something (it the manual lock) - Now press down the pin to release the disc tray from the drive. DONE : )
Hope this helps. please don't forget to leave a comment and rate if you see this solution was helpful, Thanks!
Jul 27, 2011 | Computers & Internet
Rca drc8335 will not completely start up. HELLO on display seems to get stuck and system will do nothing.
If you know how to solder then you can fix this one. Make sure unit is unplugged and then remove cover. After noting their locations, unplug the white connectors and the two AC leads from the Power Supply board. Remove the (5) screws holding the board and remove it. Find the capacitor marked C226 and make note of it's polarity. It is a 16V - 470uf Electrolytic. Carefully remove it. For under $2 at radio shack you can buy a replacement. It will be a 35V - 470uf and may have axial leads (leads out of each end). Note that the arrow points to the negative lead. Bend this down the side of the capacitor and straighten the positive lead and feed the two leads through their proper holes. Solder the leads on the underside, snip off the extra lead length. Re-install the power supply board and re-connect the plugs and the two AC leads White to pin marked White and Black to pin marked Black.
Note that the two short mounting screws go into the tabs from the back of the case. Check your connections one more time.... Replace the cover plug it in and Ta Da.
Dec 23, 2010 | RCA DRC8335
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
Have a Magnavox (31YA--??) DVD/CD recorder/player which due to moving and busy, I have NEVER installed; and have at the same time lost the manual. HAVE PLENTY of cords to match colored terminals; but "S"...
The S-Video "holes" the tv and the dvd player each have a S-Video.Hook it up with a one black video cable to the S-video to the hole in the tv and the other side to the S-Video in the dvd player.U have a RCA cable have 2 plugs lead each sides have 2 connections one RED,one White lead connections. Plug that RCA cable 2 connections in INPUT holes in the Tv ,and the other sides 2 connections one WHITE,ONE RED to the DVD player for sound.
Apr 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Cd stuck no way to eject
Hoping it's running XP or later.
1) Start the computer in safe mode - Pressing F8 after the boot but before it tries to start windows.
2) Select "Start in safe mode"
3) when active (fingers crossed) Choose Start - All Programmes - Accessories - System Tools - System Restore and restore to a date prior to all your problems.
4) Win Vista is similar but the System restore is in a slightly different place, but not sure where exactly
Mar 14, 2010 | Computers & Internet
Cd is stuck inside the player. I moved the unit when decorating and now the unit will not play any cds and there is one stuck inside. I removed the casing to look inside but got scared off when I saw all...
It is safe (except for the lead solder) as long as the unit is not powered ON.
There is a "pin hole" on the front of the CD tray.
With power OFF, use a stylus (straightened-out paperclip) to push the mechanical eject button inside the pin hole. Carefully use enough force to push the CD tray out.
Oct 13, 2009 | Audio Players & Recorders
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
Mar 06, 2009 | Emerson EWL20D6 Television
I have a DVD stuck in my Sharp LC-19DV22U Liquid Crystal TV/DVD/CD Player. How can I get it out? Vic Spigener
There will small pin hole in the dvd player you need insert a thin metal wire or pin which eject the tray....... and remove the disk..
Good luck...
Aug 03, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
