Question about Yamaha HTR-5760 Receiver
No power Hi I have a Yamaha Htr5760 Amp. It couldn't turn on. I check sub power board and there is 10 volt supply to function PCB. Chang
  • 96 Answers
Open and replace the fuse
Posted on Sep 09, 2009
Hi, I have Plasma TV Power Supply Board. The model of board is: LJ44-00144A PS-506-PH. The stand-by voltage 5Vstb works just fine. When I turn on the TV the Stand-by let in front of it comes blue like...
I have the same problem. As I see, here is dead sub PCB with microcontroller on board. Small PCB with 26 pins, mounted verticaly on main, big power supply board. It is not available as a spare part. You must buy complete power supply board LJ44-001444A, as I have done.
Aug 09, 2011 | Philips POWER SUPPLY (41644158) Power...
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Hi - We have an error code on a Canon Model 2800 : E000001-0002 Any ideas on how to fix the problem? Thanks! Paul
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Fixing film unit
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Apr 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Mitsubishi 62 inch microdisplay hdtv w/screen w/zy
I have a list of problems common to this series here:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would start with #3, checking the 5 volt line and replacing the listed capacitors if needed.
Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Red light on no picture will work fine after several minutes
There is a list of things you need to check, but offhand I'd say that the 5 volt line is low and probably right on the"edge", which is why it works sometimes and not others take a look at this list:
Cause #1
I would say try #3 first, the two caps on the pwer supply board. A couple of warnings: as always, unplug the unit before servicing. The power supply is located on the left side, if you behind the unit. It is in a shielded box and the shield has VERY SHARP EDGES so use care when you try to open it or you will slice your fingers.
Nov 08, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mits 527252 ballast
Good Day; I would suspect the ballast, but try these first:
Causes: Cause #1 1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH.
Nov 03, 2008 | Televison & Video
Wd52525 Ballast
Good Day, monkbuist;
TRY THIS:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
New Lamp turning off after 5 seconds
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
New Lamp Replacement, still a No Go.
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 Hope this helps!
Aug 21, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Yamaha HTR-5760 Receiver Logo
162 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
