Question about Canon EOS 400D / Rebel XTi Digital Camera
My canon rebel XTi body fell into a pond. I tried to dry it out for the past 2 weeks, but it won't work. It won't turn on at all. Is there a way to fix this?
  • 33 Answers
Unfortunately there is no way of fixing the issue short of replacing the parts that were damaged by water. The service is available, so all hope is not lost!! However, I must warn you that the replacement of the main board (which is most likely what is causing your camera to not power on) may not fix your camera completely as you do not know how far the liquid damage has gone.
There could be other issues such as lens damage, water spots inside the lens, etc. My suggestion would be to have that main board replaced and go from there. If you're comfortable doing it yourself, I strongly advise you to open the camera and try to determine how far the corrosion (it will look like lime build-up basically) from the water stretches before you make any decisions on whether to have the main board replaced or not.
Posted on Sep 09, 2009
How do you get to the video mode on the canon 400d rebel xti
There is no video mode on the Xti. The first Canon Digital Rebel to be equipped with video was the T1i, which came out almost 5 years later (2 years ago).
Feb 15, 2011 | Canon Rebel XTi / EOS 400D (body only)...
Can CF card pin be repaired on a Canon Rebel? Canon EOS 400D / Rebel XTi Digital Camera with 17-85mm Lens
I assume you mean one of the pins inside the camera body itself? This is quite a common problem and I believe it will have to be dealt with by a Canon Repair Centre. However it is not the end of the camera and is worth having done although I cannot say what the are charging at this time.
Sep 20, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
My rebel xti stopped working in the middle of a photo shoot
I am wondering if you solved your prooblem with your camera, the same thing happened to me and I need it fixed for my daughter's birthday next week! HELP!
Sep 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I dropped my Canon EOS Rebel Xti in the canal while kayaking.
Water in the camera body could take up to a week to dry. If you tried turning it on while it was wet inside, you may have shorted out some circuits.
Aug 23, 2009 | Canon EOS 400D / Rebel XTi Body Only...
Help! Cracked LCD display on Canon Rebel xti
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
Mar 21, 2009 | Canon EOS Digital Rebel XTI Digital Camera
CANON REBEL XTI LCD
Your battery is low ...shut the camera in off position and replace with fresh battery
Oct 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti focus issues
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
Aug 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
358 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
