I have a kenmore 17032 dishwasher. Lately, it has been not cleaning dishes very well. The big problem is that when we open it afetr the wash, there is food residue in the dishes and inside dishwasher especially by overfill protection float. Any assistance will be much appreciated.
The key is to not use the dishwasher as a garbage grinder.
I suggest that you witness the volume of water being discharged from the machine. If low volume, look inside for plugged screens.
Also, be sure to remove all food particles from the sprayer tips, which is not an easy task, get each and every piece, run machine and check again. then quit putting dirty plates in the machine, quick rinse = seriously better cleaning, and less unit maintenance.
Doc
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 17032 Built-in
kenmore 655.13222 k601 bought 5 months ago after insalation machine stops and clean light comes on...
(More)
kenmore 655.13222 k601 bought 5 months ago after insalation machine stops and clean light comes on flashing. had a repair man in changed circut board. month later of same issues told us the drain was not connected properly. today had a service man in and a wire was off to the element. now it runs a full cycle. what i would like to know is how long should all the cycles be if set to normal or fast etc. and when heated dry is selected should dished be fully dry . cause on normal - with heated dry turned on - everything is still wet like machine just turned off nore do the modes on the dishwasher change ie light stays on for normal clean but never lights up at rinse or drying just normal to clean? any one any ideas?
It leaks out of the float switch, occasionally. I think it comes from the float switch because it...
(More)
It leaks out of the float switch, occasionally. I think it comes from the float switch because it drips off the bottom of the switch. When it leaks the amounts vary from hardly any to a cup.
