Question about Dryers
The dryer works well but squeaks the whole time it is drying
  • 4,340 Answers
Get after it, while the issue is small...
So, squeaks, as compared to scraping sound....You did not mention the brand, and my telepathy is malfunctioning, so dryers have several types of bearings.
UNPLUG before you do anything, there is live power all over ...
I suggest that you release the belt and spin the drum... Still noise, disassemble until you find a dry bearing... Many dryers use oil empregnated brass bushings, they dry up and will seize.
Posted on Sep 09, 2009
Testimonial: "Thank you yes this was helpful."
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
Jun 20, 2012 | Maytag Dryers
My dryer is making a horrible noise when turned on and then when the cycle is stopping. the noise continued to happen then began going through the whole time cycle. The dryer is getting hot but it is not...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 17, 2011 | Crosley CDE6000 Electric Dryer
High pitch squeaking noise throughout the whole drying cycle, getting worse.
heatman101
Apr 03, 2011 | Magic Chef CYG2000AWW Gas Dryer
High squeak when dryer is drying
You don't mention the year make and model of dryer, but most often it is a dry bearing or bushing, or the drum is rubbing on a piece of metal that is supposed to have a nylon glide attached. It would help if you could do a "mechanic's stethoscope" to the machine to help yourself locate the source of the squeak. A "mechanic's stethoscope" is a long screwdriver or the equivalent. You put your ear to the wood or plastic handle and you put the other end in various place on the machine to try to locate the loudest squeal. When you take the whole machine apart, the source of the problem should be readily apparent.
\Be blessed.
Mar 01, 2011 | GE Dryer Repair Video Older Models
Bumping noise while drying
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jul 01, 2010 | Maytag MDE9700AYM Electric Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
While drying for short time the dryer starts to squeak
Probably a dry bearing
.You would have to gain access into the dryer to establish which bearing/s it is.
You would then need to see if lubricating the bearing/s, would cure the squeak..
If it does not, then you may have to fit a new bearing/s.\
Hope this helps.
Dec 22, 2009 | Maytag Dryers
Frigidaire FSE748Gf dryer squeaks all the time now when drying.
Drive Belt. It may work for a long time, and the squeak may go away, but the belt is worn and needs replacing.
Aug 13, 2009 | Frigidaire FSE748GF Dryer
Squeaks and sqeals during dry cycle
Lubricate the contact points, pulleys , change the felt seal .
Get a new dryer, abot time?
Vitally
May 14, 2009 | Dryers
Dryers Logo
147 people viewed this question
Top Dryers Experts
