This problem can be a number of things. 1) First, make sure you have the correct cartridges ( a 45 and a 78),. 2) It is rare, but HP can deliver a new cartridge that is DOA. 3) Make sure the electrical contacts on the cartridge are clean and dry. The electrical contacts are on the cartridge's vertical wall opposite the label. The contacts are the square gold clusters - NOT THE PRINTHEAD (never wipe or touch the printhead without the proper procedure). Dirty or wet contacts can cause this problem. 4) Contacts in the printer can be dirty, but this may require a little more expertise. You can carefully wipe the printer contacts with a dry Qtip. Give more details about the cartrdge (is it new, old, remanufactured, etc.)
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from...
(More)
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from the cartridge.
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone...
(More)
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone line is good. I probably have it hooked up wrong but I do not know. Help!
Half empty black cart stopped printing, error message to replace. New cart also didn't print. ...
(More)
Half empty black cart stopped printing, error message to replace. New cart also didn't print. Repeated cycles of clean and prime did nothing -- nothing but fill the bottom of the printer with a puddle of ink. Troubleshooting page suggests cleaning or replacing the cartridge service module. Is this possible on this machine. Is it a dead puppy or worth fixing?
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in...
(More)
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in color. Thank you.
