Question about JVC AV-48WP30 48" Rear Projection Television
In the service menu i can't figure out how to save my white balance settings once i have adjusted them.
    Problem Solver:
  • 5 Answers
SEVE THE SERVICE MENU ADJEST THE SERVICE MENU THEN PRESSOK BOTUN FOR REMOTE HAND SET
Posted on Sep 11, 2009
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
May 05, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Sony trinitron FV-32FS120 picture has an orange tint
THERE ARE ADJUSTMENTS TO THE VIDEO DRIVE THAT CAN CORRECT THIS PROBLEM/THEY ARE IN THE SERVICE MENU. WITH THE POWER OFF, PRESS MENU-5-VOL+ POWER THE SET WILL COME ON IN THE SERVICE MODE. STEP THREW THE MENU ITEMS UNTIL YOU GET TO RED/GREEN/BLUE DRIVE THEN ADJ. TO BALANCE THE COLORS WHEN DONE PRESS MUTE TO STORE THEN POWER OFF ON THE FRONT OF THE SET OR IT WONT SAVE.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
White Balance
You can change the white balance in the "shooting menu".
Nov 11, 2009 | Cameras
Tip
SERVICE MODE POWER SUPPLY AND INVERTEE CIRCUIT
White balance adjustment
Pre-adjustment
The set should be working for over 30 minutes before white balance adjustment so that it can be in a stable state. Use white balance apparatus CA210 and change to BBY channel to adjust white balance; Only need to adjust chromaticity coordinates when color temperature is 10000K (namely "COOL") for the unit. To meet testing requirements of BBY when color temperature is 8000K or 6500K, make sure chromaticity coordinates of bright scale is X=280 ± 5 Y=288 ± 5, chromaticity coordinates of dark scale is X=280± 8 Y=288± 8; Manual adjustment of both groups of white balance datum YPbPr white balance adjustment.
FOR MORE CHECK
Electronics Equipment Repair Center
on Feb 14, 2015 | Insignia Televison & Video
My tv looks green&can not be adjusted.it is a sony.serial#kds-r50xbr1
Press Menu, Video Custom Settings, adjust Hue to reduce green tone, if that does not solve your problem, go to Advance Video Settings Menu, White Balance, adjust white balance by tweaking R, G, B gain/ bias settings or hit Initial set for factory default settings.
Sep 24, 2009 | Sony Televison & Video
Can't enable manual white balance and other options on nikon d40?
white balance can only be manually configured on "PSM" modes only, the other modes set the white balance automatically .
Sep 25, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
JVC AV-48WP30 48" Rear Projection Television Logo
76 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
