Spin cycle is losing power. Will not spin without help. Spins slowly after helping it get started.
  • 1,305 Answers
Sounds like the drive belts need replacement. If the machine gets overloaded, it can overheat the drivebelts and cause this reaction. Be sure to replace both belts.
Posted on Sep 09, 2009
    President:
  • 744 Answers
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: spin cycle is losing power - 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
P.s Remember to unplug the power prior to servicing.
FRIGIDAIRE LTF2140FS1 SPIN SLOWLY
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
I cannot get my Candy GOFS262 on a 'SPIN ONLY' cycle? It just fills with water, drains and spins? I only want to spin some already wet laundry - HELP please?
this is a problem with these machine turn the selector anti clock wise slowly to spin as the contacts on the selector wear out or try clock wise but slowly some times this works
Jan 31, 2015 | Candy Washing Machines
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
The drum will turn slowly, but at the spin cycle it just clicks - even when there are no clothes in there! We just replaced the motor, and the spin cycle worked for a couple of loads, but now we have the...
Hi hgklaassens,
I have a hotpoint top loading, mine would agitate but not spin or pump out. It just buzzed and did nothing. If I drained the water, it would spin slowly.
Before you do this, disconnect the power.
I took the front panel off, use two drywall knives or putty knives and stick each one in at the top of the front panel just under the top. One in from the right and one from the left about 4" in on each side. You have to depress springed levers, once you do this, the front vertical panel will pull off at the top, hinged at bottom, then left out. The pump on mine was jammed with a nail, it could be a sock or something. The pump is connected to the drain hose from the back. Disconnect both hoses, GET READY for a lot of water, use a rubber hose to direct it to a drain. Remove the pump and see if the impeller spins freely. If not then something is either jamming it or you need a new pump. If the impeller spins freely then check both hoses to make sure they are clear. If all this checks out then you may have a different problem. My guess why the drums spins slowly is because it has a lot of water in it and the pump isn't working. Make sure you have power to the pump.
Hope this helps.
Oct 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Your washer has brake problems you need a qualified repair person
Apr 02, 2009 | Washing Machines
Spin cycle
Without any other info. this sounds like the basket drive is worn out. Depending on the brand, it has different names, but it all does the same thing. Its kind of like the clutch in your car. It has to slowly get to speed. Yours, without any clothes in it has no load. But when you add weight, it doesn't have enough power to turn it. Its slipping or just worn out. Just wondering, why did you change the water pump? Did the wheel on it break?
Mar 07, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
