Question about Craftsman Single Speed Rotary Tool
Coupler between motor and chuck disintegrated, where can I get a replacement coupler for a craftsman rotary tool model# 572.610011? Thx
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
$2.57 In stock
Posted on May 19, 2010
  • Dusty Ryan May 19, 2010
    See the nice picture of the part here
  • 4,336 Answers
Oreder directly from Sears. You want it to fit and work.
Posted on Sep 09, 2009
Will the same part work for model 572,610010 ?
Posted on May 29, 2010
The tool stopped turning...motor turns but chuck and tool freewheel
usually there is a coupling to connect the 2 parts I would think that it has cracked. If you have the brand and model number get back to me and I will try and find the part number for you or you can go to their website and look it up.
Aug 31, 2011 | Craftsman Tools & Hardware - Others
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
Aug 11, 2011 | Craftsman Single Speed Rotary Tool
I bought a cordless rotary tool Model No 572.610780 and I cann't get the collet nut to loosen so that I can put an accessory on it.
Did you engage the chuck lock? This is usually a button that you press gently as you turn the chuck and the pin on the bottom of the button drops down to lock the chuck. Then you hold the body and turn the check anti-clockwise when viewed from the jaws.
Best to read the instructions before you start playing. :>)
Feb 08, 2011 | Craftsman Tools & Hardware - Others
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
May 29, 2010 | Craftsman Single Speed Rotary Tool
Don't know how to get the various attachments on and off the tool
it is a chuck...of sorts. There should be a button to lock the shaft and then you can use the wrench it came with to loosen it.
Apr 21, 2010 | Craftsman 2.0 amp Rotary Tool Kit
I have a rotary tool single speed chuck does not
Common issue with these, the plastic flex coupling is broken-
Replacement available for $2.57 from
Number: 2615294309
Weight: 0.18
Disassembly on my model involved the following:
Remove the four Torx screws on the body, then unscrew the front end cap at the front of the tool to expose two more screws. Separate the two halves of the body to see the brittle and broken yellow coupling.
Replace with the new white coupling and reassemble. Buy spare couplings as they don't seem to last all that long.
Mar 16, 2010 | Craftsman Single Speed Rotary Tool
My craftman single sped rotart tool the chuck with
Do you have any kind of a clutch on this drive ? I may be in bewteen settings.
Please let me know
Feb 06, 2010 | Craftsman Single Speed Rotary Tool
I have a Dremel Single Speed Model 275 that belonged to my Dad. It suddenly won't turn on the end even though the motor is running at full speed. When I take my fingers and twist the end, it starts to turn...
The Dremel 275 (and other series) have a plastic coupler and spline that connect the motor shaft to the collet shaft (where the tools attach). The plastic fatigues and disintegrates, causing the collet shaft to stop, even if the motor is still running. The fix is about $5.00 --- two parts from Dremel. The 275 case is a **** shell that opens with the removal of six T-10 Torx screws.
Mar 28, 2009 | Dremel Tools & Hardware - Others
I need to replace the bent shaft that the chuck screws onto
I would go direct to Dremel.com or call them at 1-800-437-3635 and get the schematic and parts you need, I just checked and they have a parts diagram online that you can view. go to the section about manuals/literature and type in your model number. Good luck
Mar 16, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Open Questions:
Craftsman Single Speed Rotary Tool Logo
1,096 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
