Question about Saws
I have 9215-02 skil saw, but I cant get the blade to lock. Could you help me.
  • 4,336 Answers
I presume that you are trying to change the blade, I often jamb a wood piece in a favorable location while tightening or loosening..
un plug first, but you knew that, right?
Posted on Sep 09, 2009
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
New skil HD5510-01 5 1/2 inch trim saw quit running after cutting a bunch of 2x4s
Does it have any sort of blade safety lock?
Did the blade bind and possibly throw the built in circuit breaker?
If so, there may be a small pin or button you press.
Did you try a different electrical outlet?
The one you were using could have a GFP and not able to take the draw of a saw.
Jun 25, 2011 | Skil Saws
How to replace saw blade on skil saw
On the side of the saw in the center of the blade, there should be a bolt to remove that will get the blade off. Some saws have a special wrench needed to remove it, but since you have a Skil, you should be able to use either a 1/2" or 9/16" wrench or socket to take it loose and switch the blade out for one of your choice. Hope that helps.
Oct 09, 2010 | Skil 538501 120Volt 714Inch Circular Saw
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I do not know how to install blade and have no manual
Most of the skil jigsaws have a plastic piece with a spring and catch behind it. Just push your blade into the tool and it should lock. When you want to remove it you need to press the plastic lock collar up and it will release the blade. Some of the earlier models weren't as easy to set the blade in and you have to press the lock collar up insert the blade and let the collar down around the blade to lock it.
Sep 09, 2009 | Skil Saws
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Just bought Skill Saw 5150 with no blade and bought a 7 1/2'' blade and the saw has a wrench but can't find anyway to lock to undo the nut so I can replace the blade. I pulled on trigger and held it but...
hello I can help you. Look carefully around the housing that surrounds the blade and you will find a small lock button. Push it in and rotate the blade until it locks. Then apply the wrench.
here is the link to the free manual from skil
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Jun 17, 2009 | Saws
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Saws Logo
199 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
