Question about Acer Aspire One PC Notebook
The battery does not get recharged on my aspire one for some reason. i can only use it when its on AC power. how can i fix this problem?
    Problem Solver:
  • 17 Answers
Laptop batteries only last for a year or so. You will have to consult your user's manual and find out how to order and install a replacement battery.
Posted on Sep 09, 2009
Aspire 2225g works only without battery
You need to replace the battery. A lot of laptops will work from AC adapter when the battery is out but when the battery is installed they default to battery and the AC adapter defaults to charging. When the battery is bad you get the results you describe. If for some reason it did the same thing with a new battery then the power circuit would need to be replaced, but this is not typically the case. Almost every time I have fixed someones Laptop with the problem you describe, a new battery was the solution.
Mar 17, 2014 | Acer Aspire Computers & Internet
Acer aspire 5742 does't keep power on battery. itis shutdown imediatly.. how can to fix?
If the power adapter runs the laptop, it is likely the rechargeable battery needs to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search for battery.
Jul 04, 2012 | Acer Aspire 5742 Notebook
Laptop power charging stops and laptop later shuts down and no charging
First you should figure out what caused this problem. Here below are some possible cause:
AC Adapter Problems
If the AC adapter is not working properly, then the charging won't occur at all. An AC adapter, with lower than required voltage settings, will not be able to charge the battery. See to it that the AC adapter matches the laptop battery's requisite settings. A loose wire or internal breakdown, may render an AC adapter useless. Changing the adapter all together might solve your problem.
Acer Aspire 5720 AC Adapter
Power Management Software Problem
Sometimes, the problem is merely with the power management software. This is the classic case, when the laptop charges when switched off, but doesn't when the computer has booted. The software may have gotten corrupted which must be causing the problem. In such a case, go to the device manager section and uninstall the power management software. In case of Windows XP, uninstall 'Microsoft ACPI Compliant Control Method Battery listing' from the device manger section. Take care that you do not install any other AC adapter driver software. Then go for a 'hardware scan', which will automatically identify the battery and reinstall the latest version of the drivers again. That will restore the charging facility of your laptop.
Internal Charging Circuitry Problem
If neither the AC adapter, nor the power management software has a problem, then problem can be with the internal charging circuitry of the laptop. In this case, there is little you can do, other than send the laptop to the manufacturer's service center.
Bad Battery
If you have checked for all of the above, one of the main reasons, which could lead to the problem of laptop plugged in but laptop battery not charging is a bad or dead battery. Run a laptop battery test. If your laptop is quite old, this could be one of the most likely reasons. Get the battery checked from the manufacturer and check if it has exceeded its predicted recharge cycle limit. It is important that you get the dead battery replaced immediately with a new one. Laptop battery troubleshooting will solve the problem.
Hope this will help.
May 09, 2011 | Acer Aspire 5720-4230 Notebook
My 1690 don't start black screen.
There could be a couple of reason why laptop didn't start-up. Basic: the battery is dead and need to be recharged. Possibly the battery isn't keeping charge and the AC power charge is un-plug from the wall. Leaving the laptop without power. Make sure everything is plugged in and try to power it up. It that doesn't work then it could be the power supply in the laptop it self. Good Luck!!!
Mar 15, 2011 | Acer Aspire 1690 Notebook
Can i charge my samsung s860 by plugging in an adapter to the ac/dc jack on the camera when i have rechargeable batteries installed
I'm going to say no, The AC power "jack" as you refer to it as is for external power supply from house hold current this is an optional device if it came with your camera it was a bonus. Anyway back to the question this AC power will not charge batteries and the reason behind this for two reasons is heat and additional size. The camera would have to be enlarged the size of the battery charger to accommodate a charging cycle.
Dec 31, 2010 | Cameras
How to recharge Acer Aspire One netbook. I have used it with the AC adapter thinking that was how you recharged it but it didn't work.
If the AC adapter light turns on the battery is dead. Replace it.
If the AC light does not turn on try another outletor the adapter is dead. Replace it.
If this helps please vote for my solution.
Nov 12, 2009 | Acer Aspire One AOA150-1784 Netbook
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
Battery life
Try another battery cause if for some reason one of the cells inside of the battery isn't charging that will keep the rest of the battery from charging.
If that doesn't work then try another known working AC Adapter.
If neither of those work then its an issue with the motherboard DC Jack needing to be resoldered back into place.
Aug 22, 2009 | Acer Aspire One AOA150-1405 Notebook
Acer Aspire One  PC Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
