Water leak from bottom of washer - Washing Machines
    President:
  • 744 Answers
Hello, With the lack of information I will assume this washer is a top load. The most common cause for a leak on a kenmore washer is the pump. The pump is mounted directly onto the motor and is attached by 2 clips. Lean the machine back so you have access to underneath the machine, remove the 2 drain lines attached to the pump and the 2 clips holding the pump onto the motor...examine the point where the pump hooks up to your motor and you should find evidence or water leaking at this point. Replace the pump :) If you have any other question or concerns please feel free to comment again. Good Luck!! Mike
Posted on Sep 09, 2009
  • 11,896 Answers
  1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle? A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply. The other two options are when the washer is agitating or pumping the water out between cycles.
  2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking. If it doesn't, then run the drain cycle to see if it gets worse or better. Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
  3. Wait until the water has been pumped out, lift the lid and check the drip again. When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools. If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from. WARNING. You are working with a moving, electrically hot machine that could flood. You must take your time and not put your hand or hair in somewhere that can catch you. You should not have to get into the upper control center, thus reducing the shock hazard.
  4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose. Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.# There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
  5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc. Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits. Most likely, you won't find standing water, but some clues of where you should look when the machine is running. Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem. Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak. WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on. Stay clear, and watch your hair and hands. Once the machine is full and starts its cycle, look for leaks. Let the machine do its cycle and as it goes into each part of the cycle, look for the leak. Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely. Remember, water runs down; where it drips is not necessarily the place of origin.
  6. Find the leak and make the needed adjustment (which will be all that is necessary most of the time). If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Nov 15, 2010 | Maytag SAV5710 Top Load Washer
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Washer leaks water from bottom
Water pump or hose came off or broke but i bet its the water pump
Feb 06, 2009 | Kenmore 23822 Top Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My daughters maytag has water leaking from the bottom.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 25, 2008 | Maytag PAV2300 Top Load Washer
Washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Jun 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
