Question about Dell 924 All-in-One InkJet Printer
Printing Photos Until an hour ago I was able to print photos perfectly fine. Ink was low so we used the "do it yourself" ink refill injections. After filling the colors and replacing the cartridges it was able to print an alignment page, and a test page. However, photos will not print, and the messages say 1) there is a printer error and 2) printer is busy. Also, the orange exclamation point on the side of the power on button is illuminated. I have followed the instructions that the printer is telling me and still have no luck getting the photos to print. I have disconnected the printer power source and USB as well as powered down the whole system. Still nothing has happened. The second problem is there is no place that I can find that allows you to indicate the cartridges have been refilled or replenished. HELP
I refilled color ink for Dell Photo 924 but some reason it showing it me low ink.
Posted on Dec 20, 2007
Canon pixma pro9000 -2 i have done all the print head cleaning and deep cleanig and the test shows no cloggs -- when i print specifying low quality ( fast ) and plain paper, the photo looks marginal...
Hello Charles! Welcome to FixYa!
Actually as you told that you have replaced ink cartridge sometimes ago so with the new ink the effect of primary colors is more and when you print on the high quality the effect of primary color is more.
If you are printing the photos with software the try to print it on medium quality, even on low quality, The result will be fine. You can change the setting of printing in any software. After a time while when the ink will be used the result will automatically fine even on High quality.
I hope you have a clear picture in your mind.
Sir, If you find my service helpful for you then please don't forget to Rate the Service as "Five Stars" and give Words of appreciation as Feedback
Thank You for taking my service and using FixYa
Dec 17, 2011 | Canon Office Equipment & Supplies
My printer is printing dark black at first then the bottom of the page is light black. I have tried shaking the ink cartridge and I don't believe it is old enough to be out already. I just replaced it a...
The amount of time is not a factor, it depends on how much printing you have done. If you have printed a lot of photos the ink get used very very quickly.
The way to improve the print quality is to use the maintenance option to clean the print heads, but it sounds like low ink.
Jan 19, 2011 | HP Photosmart C3100
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Jun 16, 2009 | HP DeskJet D1460 InkJet Printer
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Photo printing
Epson printers use pigments type of inks you may have purchased a dye type of ink.
Sep 20, 2017 | Office Equipment & Supplies
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Photo printing
What program are you using to print out photos?
Try to take the ink cartridge out and put it back in.
Go to this link, instructions on how to replace ink cartridges
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
And then try to print. If you have the same problem, try to use another program that you can print pictures from.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
112 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
