Question about Sony STR-DE485 Receiver
Remote's will not work with my Sony STR DE-485
My Receiver has worked fine for years but all of a sudden none of my remotes work on it. I had 3 that could but now none will, any ideas?
    Problem Solver:
  • 5 Answers
The ir feed receiver amplifier has failed a common sony fault on older units a fix is about $100.00 or use a repeater ir blaster from circuit city for $40 and try that you can return if no success the repeater eye covers the receivers originaland pumps up the out put into the unit
Posted on Sep 09, 2009
3 Suggested Answers
marklights54
  • 12 Answers
SOURCE: Yamaha remote to command Sony CD changer.
isn't that nice of them to just list the yamaha code for CD players? I sent yamaha an email about it. we'll see what they say...
have you checked out the new universal remotes that are out now?
http://universalremote.com/consumer/products.php
http://www.compuplus.com/i-Universal-Remote-Control-URC-R50-Digital-R50-Universal-Remote-Control-1028369~.html?sid=jn84494w6bxh2e2
Posted on Mar 01, 2009
SOURCE: Sony STR DE 485 is locked on Protect mode
Change the audio amplifier IC damaged
Posted on Jul 09, 2009
The 1/4" headphone jack broke on my Sony STR-DE 485 receiver. How do I replace it and what it the part number?
1-683-763-11 is the p/n for the headphone board. Should be easy to replace. Just unplug the old one, take take the screws out, and put the new one in.
Mar 30, 2013 | Sony STR-DE485 Receiver
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
Mar 01, 2010 | Sony STR-DE485 Receiver
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Feb 08, 2009 | Sony STR-DE197 Receiver
Sony STR-VX550 receiver does not respond correctly to commands from optional Sony RM-S750 remote commander. Remote is working properly and activats all functions on my other STR-VX550. Only on/off command...
If this is a recent occurrence, unplug receiver for 20 minutes. This will reset the receiver. If the remote is programmable, reprogram it for the receiver. If you do these steps and it does not work, you need a different remote.
Aug 22, 2008 | Sony Audio Players & Recorders
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Remote Doesn't control stero
Blinking doesnt always mean that the IR transmitter is working in the remote.
Check a couple-few of the online remote dealers you may be able to get one cheap.
Feb 24, 2008 | Sony STR-DE875 Receiver
Sony STR-DE485 Receiver Logo
454 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
