Question about Cycling
I bought a 2009 pacific 24'' girls bike. did not receive owners manual. What does 18 speed torque drive twist shaft mean? and how does it work?
  • 192 Answers
HI,
In addition to having been a bicycle mechanic and enthusiast for a great number of years, I purchased the same Pacific bike for my daughter.
The torque drive twist shaft, is their overly technical name for the twist shifter that one uses to change between gears. Some bikes have a toggle shifter, which is a little lever to change the gears. These bikes have a shifter that twists on the handlebar to switch through the gears.
By the way, the manual would not have been helpful. They give a generalised manual with all of their bikes apparently, that have non-specific information about general assembly, lubricating different parts, tire inflation, and bike safety.
We got ours direct from the factory, and the manual that came with the bike was simply the most unhelpful publication I had ever seen.
So there you have it. If you have any additional questions, please write back.
Thank you for using FixYa.
Posted on Sep 09, 2009
Testimonial: "Thank you so much for explaining this to me. Not only did you explain it, but in terms i could easily understand. "
What is the torque for the belt pulley on the rear tire of a 2009 Harley Davidson nightster 1200
Hi, Harley, that's easy 45-55 ft. lbs. for this scenario, you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Bolt Torque Values
http://www.carlsalter.com/pdfs/harley-davidson-2010-sportster-service-manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
Download Manual 2009 Harley Davidson Nightster Owner Manual
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak with me personally absolutely "FREE"
Mar 03, 2017 | 2009 Harley Davidson XL 1200N Sportster...
Why does it make a clunking noise when rolled about in the shop?
Hi, Anonymous I just loaned my brand new pair of listening ears to your local dealers chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. For more information about your issue, please visit the websites below. Good luck and have nice a day.
Loose Pulley Nut
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD PDF to Flipbook
http://www.pdfking.com/2009-yamaha-v-star-950-motorcycle-owners-manual
Dec 23, 2015 | 2009 Yamaha V Star 950
I need an owners manual for a pacific evolution bike
Are you sure the derailer or sprocket are not bent? The next thing if not that is the cable itself is it pulling the delairer to release the gear from the gear it is in? one final is the bike just may not go into 6th gear depending on which gear you have the front sprocket in because it would pull the front sprocket to far past the crank space where the pedals are at.
Jan 12, 2013 | Pacific International Pacific Evolution...
The chain is broken off the bike We bought a new one but need a diagram of how to weave the chain through Thanks
The chain goes from the top of the front sprocket to the top of the rear sprockets, between the rear sprocket and the top derailleur wheel and then between the upper and lower derailleur wheels. It then goes forward toward the front sprocket. The text sketch below shows the rear sprocket, chain and derailleur.I hope this helps.
(O
o)
(o
Aug 15, 2011 | Pacific International Pacific Evolution...
Girls 24inch glacierpoint magna bike can't raise handle bars seems like a allen type screw in middle of bar just turns and still can't lift bar does that need to be replaced or is it something else
If that allen screw just turns both directions, and it won't tighten and it won't raise up when you loosen it, then the wedge nut at the other end of that screw has already fallen off inside. Or it could mean that the screw is broken. Turn the bike upside down and see if you can remove the screw. If it is broken, the repair will be difficult, but not impossible for a bike mechanic. If the screw comes out intact, then the only thing holding the handlbar stem in place is a bit of rust. Put the bike back upright. Stand over the bike as if you were going to ride it. Grip the front wheel between your knees and twist the handlebars as if you were steering while preventing the wheel from turning with your knees. Once it breaks free, pull it all of the way out. Turn the bike over again and the wedge nut should fall out. When you reassemble, take heed of the marking on the handlebar stem so that you don't raise the stem too high. Good luck. Please vote if you found this helpful. Al K
Mar 07, 2011 | Pacific International Pacific Chromium...
The gears will not change at all. It seems like the part that you twist to change gears is seized on both sides. This is causing the bike to ride very slow.
Actually, it's causing you to have no gearing options. If you were Lance Armstrong the bike would move fast ;0) even with a flat tire.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Crimped, corroded shifter cables can prevent accurate shifting. I'm thinking you need a bike mechanic to look at it.
After it's all fixed you might want to view some resources concerning shifting, braking and general riding skills. It's all out there.
Feb 23, 2011 | Pacific International Pacific Evolution...
Cycling Logo
176 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
