Question about Sharp AQUOS LC-32D43U 32 in. LCD Television
My remote does not have the sleep timer button.
I have an LC-32D43U. my remote does not have the sleep timer button. how do u activate the sleep timer without it?
  • 405 Answers
Open cover on the bottom part of the remote SLEEP button is there.
Posted on Oct 24, 2009
We lost the remote for home theater system during our last move. Somehow, the sleep timer got activated, even though there is no remote. How do I shut it off again without the remote?
It's a bit weird that the sleep timer keeps coming every time you power up. Have you let it shut itself down by allowing the sleep timer do it? If it still does it then, and there is no button that will cancel it on the unit itself, try pressing them all, then you will to get either a universal remote or see if there is an original. As I don't know the make or model number of your system that is the best answer I can give.
Feb 02, 2016 | home Audio Players & Recorders
Disengage the sleep timer with no remote
You need the remote control to shut off the sleep timer. There is no other way to do it. Buy another remote control.
Sep 28, 2014 | Sharp LC-15AV7U 15 in. LCD Television
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I am trying to turn off a sleep timer that is built into a rca universal remote
When you press a sleep timer, it sometimes is all you can do to activate it,
but when you press the button again shortly after, the time on the sleep delay
will change, eventually to being off/cancelled. ?
PLEASE RATE THIS ANSWER
Aug 13, 2011 | Televison & Video
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
May 28, 2010 | Panasonic TH-46PZ800U Plasma TV
My tv keeps going off at every 30 minutes where is the timer,it also blackout
sounds like sleep timer is on. look on remote for sleep button or it may be in tv menu.
Jan 23, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just purchased a used Sharp Aquos 32 LCD model # LC-C3234U without the remote. I have Direct TV and the television needs to be on channel 3. With the buttons on the television the closest I can get is...
Try encompassparts.com and see if they have the original remote. The channels you are getting are digital channels. You are going to have to get it back to analog channels.
Oct 12, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
How to turn on the sleep timer with a comcast
press tv,press setup until 2 blinks,enter 994,press setup briefly,enter049,press the button you want to put the sleep timer on or off
Jul 10, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
SAM BD-P1500 Remote won't work with Sharp LC-32D43U
If you are trying to use the remote that came with the dvd player you most likely can't get it to work with the TV. If it IS in fact a universal remote, then you need to check the codes that come both with the tv and with the remote. Post back with any more questions or info for further help. Thanks for choosing Fixya!
Jun 05, 2009 | Samsung BD-P1500 Blu-Ray Player
Sharp AQUOS LC-32D43U 32 in. LCD Television Logo
1,998 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
