Question about Maytag Neptune MDG5500AW Gas Dryer
How do i get to the inside of my dryer, I think my son pulled the lint catcher out and i think an item of clothing got sucked into it
  • 304 Answers
The Service Manual can be downloaded at this link. It gives complete instructions, with pictures, on taking everything apart. Look at it and see if you want to tackle it. Good Luck. Turn power off first.
MDG5500
Posted on Sep 09, 2009
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
My clothes are covered in lint
Hello Pam, Take the lint screen over to the sink and gently wash it in dish soap and water. Let it dry and try it. Sometimes the small holes in the lint screen plug up from using fabric softener and/or fabric softener sheets. It doesn't take much to restrict the airflow through the lint screen.
Feb 14, 2014 | Samsung DV330AE Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer take too long to dry the clothes.
hello. When the dryer takes too long, it is a sign that lint has built up in the vent pipe, in the rear of the dryer or even in the lint catcher. Check out all of these areas and remove the lint.
Jan 09, 2010 | GE DBSR453EBWW Electric Dryer
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Wont dry clothes is hot inside dryer but takes 3 or 4 cycles to dry load
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
I can not find the lint catcher on my stackable unit
Open the dryer door and look at the lower outer edge of the opening where you put the clothes in. It should pull straight up and out.
Jul 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer has hot air but takes 2-3 hours to dry clothes. What can I do?
This is almost always due to lint build up in the vent pipe. pull the dryer out from the wall, disconnect the vent pipe. look inside the rear of the dryer and into the pipe. remove lint that is present. go out doors and examine the vent from that end. finally remove the lint catcher in the dryer and look in there. remove any lint you see.
Jun 22, 2009 | Dryers
I have a kenmore gas dryer 110.74832400 doesnt heat
You stated you checked all lints roblems. Just to make sure. Did you remove the lint catcher completely on the inside? If not take that off and clead the lint out of the inside of the duct. Also lint can build up inside the lint duct on the rear of the drier and in the duct going outside of your home.
Jun 03, 2009 | Kenmore 75962 Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
171 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
