Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
I can't shut down my computer because if I need to I will have a hard time to turn on.When I press the star button ,the computer makes a noise and won't start, then I have to turn of and try several times to turn on.
  • Dell Master
  • 4,924 Answers
Probably you have some issues with a blue screen error and a change of ram memory ...they ussually do this kinda trouble on boot when the ram memory its not quite compatible or has some issues...so ..remove the ram mem ...check if its ok ...be carefully not to touch it too much with your hands ...it has something to do with magnetization , check to be the right freqvency ...then try to reinstall the operating system ..cause if it has some issues on reading boot files it does that too...this might also came from a damaged HDD (bads on the hard disk ) and when it gets some files from the system located on those damaged places ..it does this too...so ...check memory ...then reinstall ...it just might fix the problem if you know that you didn't made any hardware changes lately
Posted on Sep 09, 2009
My Canon camera turns it self off when I press the start button. the lens comes out & then the camera shuts down. When I restart it the lens retracts 3/4 & then comes right out & shuts down again. the lens...
hi, the camera must also be giving a lens error and must be making a whirring sound when turned on, hold the camera with camera off bang it with flat of hand , a few times , if this does not work , repeat it with camera on, even if this does not, when turning the camera on gently apply pressure on the front of the lens, do this just once , all the above fails , camera has to be service , lens unit may have to be changed
Aug 27, 2016 | Canon Cameras
Factory reset on presario cq58
Back up to your external hard drive all of the items on the computer's hard drive that you would like to keep. The hard drive will be completely erased during the recovery process. Open the "Start" menu and then click "Shut Down" to turn off the computer. Allow the computer to completely shut down. Press the power button to turn on the computer and then press the "F11" button when "Press <F11> for recovery" is displayed on the bottom of the screen. Select "Recovery Manager" from the utility screen. Click "Advanced Options" and then select "System recovery." Click "Next" to proceed. Follow the on-screen instructions to complete the recovery process.
Feb 02, 2013 | Computers & Internet
Factory rest on a presario cq58
Feb 02, 2013 | HP Compaq Presario V2000 Notebook
How to go back to factory settings
All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
-Shut the computer down completely
-hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
-when the computer starts beeping release the 0 key
-when the prompt comes up choose YES to continue with system recovery
-Select recover of factory default software and click NEXT
-Click Next again to start recovery
Hope this helps!
Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
My computer will not turn off how do I make it turn off.
Select "Turn off" or "Shut Down" by clicking on it. orClick on Start button>Turn Off or "Shut down" computer. else, Press the power button of your CPU for a few seconds.
Hope it will be helpful to you
All the Best!
Nov 12, 2010 | Computers & Internet
Apple 20 in Imac G5 turn on for about 40 second and shut it down itself .. please help
Sounds like you need to reset your SMU and NVRAM:
To reset your SMU:
  1. Turn off the computer by choosing Shut Down from the Apple menu, or by holding the power button until the computer turns off.
  2. Unplug all cables from the computer, including the power cord.
  3. Wait 10 seconds.
  4. Plug in the power cord while simultaneously pressing and holding the power button on the back of the computer.
  5. Let go of the power button.
  6. Press the power button once more to start up your iMac.
To reset your NVRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
If those don't resolve the issue, your computer will probably need service. Good luck!
Oct 10, 2010 | Apple iMac G5 Desktop
My HP won't shut down. I hold the button to try a
Try this: Go to Control Panel-Display-Screen Saver-Power-Advanced tab and make sure that after the statement "When I press the power button on my computer" choose Shut down. Then turn off your pc with the power button (if it does not work unplug it, then try the button after Windows complete it's boot-up. Let me know how it went.
WBTech
Feb 01, 2010 | HP Computers & Internet
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Help hard drive is down fron pressing pc buttton
Your computer is in STAND-BY position..
RE-PRESS the same button, and your computer will be back to normal
Nov 05, 2008 | Computers & Internet
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
