Question about Canon PowerShot S30 Digital Camera
Trouble with lens and blank screen
My camera was dropped and now the lens will not close and the screen that normally shows pictures that have been taken is blank with 'E18' written in white on the bottom left hand corner. When I switch the camera on it makes continuous beeping sounds and then switches itself off. Am I able to fix this problem myself or do I need to get it repaired?
Http://www.e18error.com/repair.htmls shows pictures of how to take apart a similar camera.
need an online translator from Bulgarian.
Canon Repair is out of the question.
Posted on Dec 10, 2007
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
The LCD screen comes on but is blank. Cannot take or retrieve pictures.
Hello my friend,
Did you drop the camera ?
Basically this can be Lens broken or screen broken. you can check that by:
1. try to move your hands around the lens and see if it will change something. 2. take a picture even tough the screen is blank and then take the memory card and insert it into your computer, if you can see the picture on your computer that means the screen is broken. but if you cannot see the picture on PC that means the Lens is broken.
Oct 29, 2009 | Samsung Digimax S630 Digital Camera
When i turn my camera on, its a blank screen with
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
Powershot 200 will not take pictures, displays E18 on otherwise blank screen. Will show pictures stored on card -just will not take any new ones. Lens cover seems inoperable as well.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 20, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Olympus FE-210
Hey dramaqueen79,
It sounds like you have internal damage to the camera. I would have it looked at be an authorized service center. If you are fine with the performance of the camera and all you want to do is be able to upload your images you could purchase a card reader(for an xd memory card) that connects to a usb port, and upload your images directly to your computer with the card reader.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 24, 2008 | Olympus FE-210 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
E 18 problem
Your A410 problem really sounds like it might be a defective CCD imager. Canon would normally fix this for you for free, including free shipping both ways. http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Unfortunately this is only for applicable cameras A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
But you may want to contact canon anyways to see if they will help.
As for your SD500 e18 issue,
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Nov 05, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot S30 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
