Flashing record (orange) and power (blue) light
Same problem as described above. Worked fine. Went to bed. woke up last Thursday (Sept 3 2009) to flashing orange/record power/blue light. Hit reset button. unplugged machine. no joy. left on vacation. Came back Monday. Came back from vacation to same flashing lights, reset, unplugged, called direct TV. Was on hold for quite a while. Finally got technical support. while talking, out of no where DVR started rebooting. Went through entire reboot cycle, did system test. All was well. Turned off TV/DVR and went to bed.
Woke up this morning to flashing lights. Went to work. Came home. Same routine, reset, unplug, no joy, called technical support. While talking to technical support, started re-booting by itself AGAIN. No ****! Ran system test. All's fine. I don't know if they are resetting something while they are talking to me or it was just a coincidence ...............
We'll see if it still works tomorrow............
centralhigh
  • 260 Answers
SOURCE: Dish VIP 622 constantly resetting
You have already completed all the main steps to try this on your own. Your receiver is going to need internal repair. You can use our premium service for step by step instruction or you can contact a local repair service by using our Repair Service search engine on this site.
Posted on Jun 28, 2008
  • 86 Answers
SOURCE: My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
Posted on Mar 19, 2009
preachw996
  • 1179 Answers
Welcome to Fixya. It is more than likely that this is a result of a new bootstrap software package being downloaded to your reciever. If you do not allow it to fully complete then it will continue to retry and reboot everytime you turn the power on. Best suggestion would be to check the screen to see if it is updating and allowing it to completely finish. If that still does not correct the problem then you will need to contact Dish Network technical support and see if they can assist you over the phone. If they cannot correct the problem this way then they will dispatch a technician to your home to investigate and correct the problem. I hope this helps you to get your programming back on as soon as possible and thank you for allowing me the opportunity to assist you. Have a great day.
Posted on Apr 03, 2009
  • 56 Answers
SOURCE: Direct TV DVR record light on, but it won't do anything
contact directv 800-531-5000 if you have the protection plan a new receiver will be covered under most circumstances. sounds like a bad receiver. hope this helps
Posted on Apr 05, 2009
SOURCE: Directv DVR R15-500 problem
Same problem here -- blue power and amber record LEDs flashing on powerup.
Looked and sounded like a power supply problem, so I opened it up and noticed the bulging caps (C7, C8, C10).
Replaced with parts from RadioShack: C7 and C8 with 1000µF 35VDC, and C10 with a pair of caps in parallel: 1000µF and 220µF 35VDC...I had to enlarge the hole in the PCB with a 1/16" drill bit to get both sets of leads through (drill from the copper side, and be careful!).
All systems go.
Posted on Aug 05, 2010
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Constint blue light
It means WiiConnect24 is on and you have a message. To turn off WiiConnect24 when you are finished playing the Wii, press and hold the power button until the light truns to red.
Jan 30, 2009 | Nintendo Wii Console
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
426 people viewed this question
Top Televison & Video Experts
Electro Med Services...
